Official Nitro Evader ST Thread v2.0
#6976
RE: Official Nitro Evader ST Thread v2.0
every piston and sleeve that is new need breaking it, as they piston and sleeve have different tollerances and need to be seated to each other in runnin temp, ie thats why the heat cycle break in method is far superior to the rich break in
#6977
NY
oh yea, you're probably getting hammered with hurricane noel right now. Should be sunny skies tomorrow! I am running my MGT at my track tomorrow! WOOT!
ORIGINAL: N49185
LoL, got it Im gonna do some serious driving tommaro, waiting for this rainy weahter to pass by...
#6978
ok i wanted to drop a .21 engine in my vader. the one i had in mind was this.
http://cgi.ebay.ca/ws/eBayISAPI.dll?...0%3D%26fvi%3D1
i know its an sg shaft, but i know u can buy nuts that will hold the flywheel on. after that all you need to do is put the bell on like normal. what i am concerned about is the length of the shaft, and if the mounting holes are the same. i know this is a .21 smallblock, and i ahve heard theya re the same mounting. i was wounderin if anybody has tried this or knows of any tips in gettign a .21 into the vader.
#6979
it sais no where that its a small block, it has big block mounting dimensions, so u will need to retrofit a BB engine mount onto your evader, and u will have to seriously have to beef your driveline up as it has trouble keeping intact with a OS18CVRX
If u want all out power get a OS18TZ, it will have just as much power as that cheap taiwanese toki motor
#6980
ITS ALIVE!!!!!!!!!!!!!!!!!!!!!!!!!!!![>:]
HAHA so happy, ok my first offroad nitro truck was a nitro evader, it ran great and at 4 gallons the motor was worn, as it is a ABN sleeve not ABC, nickel being alot softer than Chrome. Anyway, it sat in my wardrobe for id say about 1.5 years.
A couple nights ago i was playing with the DTX18 engine parts (evader engine) and looked over at my AE 15 engine parts LOL (ntc3 engine)
i mixed and matched parts and came to the conclusion that hey, the AE15 sleeve and piston fit into the DTX18 crank case perfectly and line up with all the ports perfectly, the rod slips over the crank pin with no slop at all either, so i installed the piston and sleeve, put the backplate back on and installed the AE15 cooling head, Perfect.
Today i picked up bartmans worn out Great vigour motor, they are basically the same motor the DTX18 and GV15, cept that the 18 hasa larger bore
I gave the DTX18 pullstart to a mate, so the pullstart came of the GV15, and onto my frankenmotor
Just then i took it out for its first run, started it, super rich, tuned it up a little and its a little beast, no wheelies like the old 18, but top end and bottom end is a nice medium.
So the little nitro evader is back up and runnin, thanks bartman for t he parts motor, its greatly appreciated, Cant wait to take the evader to the BMX track
#6982
RI
My truck has some issues it seems, when it idles lots of blue smoke comes out, but it seems when i run it, it seems really lean, but i have it at 3/12 turns out on the HSN, still lean? lol..., and after a point on a throttle, it locks up and its toattly weird..., can someone end this madness for me?
#6983
the only 21 that uses small block mounting dimensions is the OS21TM which is made for the revo. U will still need to do a bit of modding, get a rear exaust pipe/header, re do your linkages as its a slide carb etc.
There really is no point to a 21 in a lightweight ST, the 18TZ will be just as uncontrolable as a 21. Also even the 18TZ will tear your driveshafts to bits, a guy on here had a 18TZ in his vader, every couple of runs he would have to replace the driveshafts as it tore t hem to bits
#6984
CA
ORIGINAL: docphysics
ORIGINAL: N49185
#6985
NY
I run 40 series mulchers. They have a low profile for stability and get really good bite. You can see them in the pic below.
#6986
so annoying, looks like il be needing a rebuild kit for the diff, it just loosens its self to quick, i might look around for a locknut that will work, maybe its just that, and its proly the thust bearing as well, as it only has 3 balls in it
What does a diff cost on ebay?
#6989
NY
http://www3.towerhobbies.com/cgi-bin...7&I=LXEW06&P=K will those bolt right on to the nitr evader st with out any adapters? and im stuck between the dirt works and the moab tires?
#6990
NY
sweet i just converted a OS 18 CVR in to A CVRX. All u need to do is change the crank(i think thats wat its called) from a cvrx and put it into a cvr and thats it and now just have to put the back plat on and im done then i also need to run down to my lhs and get a dang collet. do hardware stores carry them? and the reason i did that was my one cvr was brand spanken new and the cvrx looks like some one drove it through hell and back. but the internals looked good so now i have a spare engine or i can use it for parts. also is their suppose to be a gasket like the dtx has on the back cover plate or just an O ring?
#6991
PA
#6992
NY
oh man, the track was in great shape yesterday, perfect amount of moisture in the dirt. And the MGT was running super strong. The slap wheelies were awesome. I am planning a bash there for this saturday, so if you guys feel like driving for a few hours, c'mon over!
ORIGINAL: N49185
hey...docphysics how was the track and the MGT yesterday?
#6993
NY
dang they dont have one but he'll get a collet in thursday.
also Doc this is the local shop near me in fonda they do have a track but they dont have pics up and they r getting a oval track soon too http://www.masterhobbiesny.com/
#6995
NY
i have never even raced the truck yet im scared lol. i want to this spring. It sucks having 2 big hobbies. 1: i drag my 02 v6 mustang on the weekedends and wed nights at Lebanon Valley dragway and now this my rc truck is costing a small fortune but luckly its winter or close to it so im only spending $$$on the rc truck
#6996
NY
Converted OS 18CVR in A CVRX and then put the old cvrx into a cvr???[sm=72_72.gif]???
LOOK what she's packing
MY Truck
spare mortor that i took the crank and pull starter from. used it to transform my new CVR into the CVRX and now i have spare parts too. and it did run b4 i tore it apart
now all i have to do is cut a few holes in the body so it fits and pop a few holes in the winshield too. and by next week ill have more pics up with the new hop ups im getting from tower
MY Truck
#6997
NY
and u guys said to use this for the carbide ball? http://www3.towerhobbies.com/cgi-bin...?&I=LX2765&P=K
#6998
NY
is the duratrax micro fail safe any good?
sweet i just found some Mashers i bought like 2 years ago when i bought the truck and only used them for like 2 mins.
#6999
NY
if you run a NiMH hump pack then the duratrax fail safe is awesome. If you run alkalines in the truck, then that fail safe is always kicking in and becomes a PITA. Its not only signal, but voltage dependent.
