Official Nitro Evader ST Thread v2.0
#8226
NV
RE: Official Nitro Evader ST Thread v2.0
when I rebuild my engines, I use O2 sensor safe high temp silicon. just use it very sparingly. let it dry for 24 hours without any oil. then reset the carb to factory settings, then break it in the right way.
#8227
NY
it not 2 hard to make them. u just need 1 tool: needle nose pliers or a regular pliers. one to hold the link and one to bend it open
1. go to the hardware store and buy 10 feet of chain of your choice(i payed .69 cent a foot for mine)
2. take a piece of chain and put it one the inside of the tire near the rim, rap it around near the rim
3. cut it/open a link so u can take it off from the rest of the chain
4. put it alongside of the main chain and measure out one for the other side
5. hook 1 chain together and then do it for the other side too
6. now u need to figure out how many links u r going to need to make it to the other side.(my moabs used 10 links across)
7. make about 7-10 of those
8. now u can open both ends of it and hook one to one side of the tire and then to the other, then close the ends
9. count of like 4-5 spaces after the one u just hooked up and then place another
10. do this until u r satisfied and think u have enough
11. u do want to make sure the chains on the outside of the wheel next to the rims r tight but not to tight. shouldn't really have any play in them so u may have to take out a link or 2
#8228
NY
hey evader st 9887
its a CVEC tunable pipe
It's a small block pipe, and you can adjust it for torque or high end by stiffening the spring/piston inside the muffler. and yeah i did get it with one of my os engines.lol
#8230
NY
what servo is better
the Futaba S3305 specs: tad faster speed but less torque
Speed: 0.25 sec/60° @ 4.8V
0.20 sec/60° @ 6V
Torque: 124 oz-in (8.9 kg-cm) at 6V
99 oz-in (7.1 kg-cm) at 4.8V
or the Hitec HS-645MG more torque but less speed
SPECS:
Speed: 0.24 sec/60° at 4.8V
0.20 sec/60° at 6.0
Torque: 106.93 oz-in at 4.8V (7.7 kg-cm)
133.31 oz-in at 6.0V (9.6 kg-cm
they look sooooo close i just cant tell. im running the s3305 for stearing but i want to get another but im not sure what i want
0.20 sec/60° @ 6V
SPECS:
0.20 sec/60° at 6.0
#8232
NY
well i just spent another 110 at towers. but after i get all this ill have an ALL ALUMINUM NITRO EVADER ST. WoOt damn i spent alot of $$$$ on this thing.lol
Golden Horizons Rear Hub Blue Evader ST 1 $21.99
DuraTrax Shock Spring Rear Green/Hard Evader ST (2) 1 $3.59
DuraTrax Shock Tower Rear Aluminum Evader ST 1 $33.99
O.S. #5 One-Way Clutch 1 $23.99
DuraTrax Nylon Body Post White 1.5" (2) 1 $1.99
HPI F-350 Truck Body Nitro MT/Rush 1 $19.29
#8233
TN
hey bigstang, I looked up the hpi 350 truck body on tower. Thats exactly what I have been looking for! Is it a good fit for the evader or is there alot of mods to do for a good fit?
#8234
NY
all u have to to is get the Nylon Body Post White 1.5 and take your stock front body mont and cut off the little nubs and then screw these in from the other side. doc has this body too and this is what he did
heres the link http://www3.towerhobbies.com/cgi-bin/WTI0001P?&I=LXD236
#8235
TN
thanks bigstang. I have seen pictures of doc physics ride and the body looks sweet!! especilally when you are a ford man!!
#8236
NV
I use the Hitec HS-645MG in all of my T-Maxx's I like the heavy torque to move the big tires. AS for the rest of my cars? I use whats on sale, or the best price, BUT, I like Hitec. they seem to take a lot of pounding and don't fail. I've had the first one for almost five years and it's still going strong. JUST remember one thing, I keep freshly charged batteries in the T-Maxx's. It's your car, get what you like.
http://cgi.ebay.com/Hitec-645MG-High...QQcmdZViewItem
Price went up. last week it was 25.99 + 3.99 Shipping.
#8238
NY
I'm a ford guy too!
There are those white body post extenders we were talking about. That is the only mod you need.
#8240
NY
#8242
NV
What servos do you guys use??? I was just thinking, that I've always used upgraded servos for steering but not for throttle/brake. the steering is the Hitec HS-645MG for the T-Maxx's. but stock in everything else. so what do you guys use for your throttle/brake servo???
#8243
NY
i still have the one that came with the truck when i bought it new like 3 years ago lol. but for steering i bought a Futaba S3305
#8245
NY
well the steering ones go out the most, unless u get a metal gear servo which the gears cant strip from taking a small hit in the front unlike the plastic gear servos can very easily.
#8249
NV
#8250
NY
i still say they r just plastic just a little stronger. if u get the 2nd one u might as well get a METAL gear servo for the same price
