Official Nitro Evader ST Thread v2.0
#8676
AB, CANADA
RE: Official Nitro Evader ST Thread v2.0
ORIGINAL: dan95-5.0
heres a pic i got when i bought it. the tank is a leaker and im tired of it.
i also have the same problem as DuratraxNEST with the spinning tires.
my HPI RS4 never had the problems that this thing is having
ive had some problems with my evader, but once you get the bugs worked out its a great car
#8677
NV
I love my BX. the thing will do wheelies with the right tires on it. the bad thing about the is they don't turn for the life of them. so stock up on the front A-Arms and get a bigger front bumper for it. to conver it to an ST you will need a new front and rear shock towers, the ST A-Arm, turnbuckles, and front tires. and thats it. I think.
#8678
AB, CANADA
ORIGINAL: greywolf187
#8681
it is the same, its the same car, just converted to buggy
It runs shorter front and rear arms, shorter turnbuckles, it has shorter shocks, comes with higher geared CB and Spur, shorter driveshafts, slightly different shock towers, body, narrower tyres and a few other little bits
#8683
PA
Looks awesome!!!! I don't suppose you have any spare, new, plastic diff gears laying around?
#8684
NV
it will center itself. when you rebuild the diff every thing needs to be re broke in. to do this you run the car at in figure eights NO more than half throttle for about two tanks. then readjust everything again. and re adjust about five tanks after that. just to check that it has not come loose. I use about ten foot circles. I get through the first tank doing that then I'll do a straight run then a few figure 8's then a few more straight run then the eights again till the tank is out the re check the diff to make sure it's still tight.
#8685
AB, CANADA
MAN IM HAVING SUCH HORRABLE WITHDRAWLS I NEED TO RIP MY CAR!!! cant wait till my new moter gets here.
id take my rs4 out but the roads arnt quite dry and thier still kinda dirty...lol i baby that thing
by the way no happens to have a extra pullstart for the dtx .18 they want to send me do they, lol i orderd all the parts to fix it but i forgot to order a pull start mine was completely messed
#8687
Alright guys, I'm at the end of my rope here. I rebuilt the stock engine and started the break in. I've made it through 5 tanks and now I have a problem. The only way I can get it started is to hold the throttle wide open. Then when I let off the throttle the truck dies.
I'm just about ready to toss it in the junk room and say the #$@! with it.
#8688
TN
ORIGINAL: Evad77
If it's not your idle, then it's your tuning. Your lsn/hsn might be too rich and just giving the engine too much fuel, which is typically the case after break-in since all the needles are set rich from the factory. Try leaning out the hsn a bit, but don't over-do it. I wouldn't go farther than a full turn from factory settings.
#8689
NY
change the glow plug, check the clutch spring, and shoes, make sure they aren't rubbing the CB at idle, and set the needles back to factory spec, you should be fine.
#8690
Thank ya guys. I leaned it out to 1 1/2 turns and it is running great
I was afraid to go down past 2 turns but after 3 tanks at 1 1/2 it is still running strong.
#8691
PA
Hey guys, need an opinion on the breakin of my new alum. diff. In the past(with the plastic diff.) I would tighten the diff. all the way, then back off about an 1/8 turn or so, run a few tanks thru, then repeat. After the diff. was broken in, I would generaly run the diff. tight and adjust my slipper. My question is, do I do the same thing for the alum. diff. or should I break in with the diff. tight or a little looser?
#8692
Hey guys,ive been gone for a bit.I got the hyper 7 and built it up to being an A-main 2nd place car with a mediocre driver.Anyways,I was going to put the evader st up on ebay tomorrow but figured id let you guys get first dibs or let me know an asking price on ebay.So My stock DTX 18 engine crapped quite quickly so I just need to mail it in and have them send me a new one but figured id sell the car with the old one and my reciept.The buyer can deal with duratrax.I have new proline bowties on the back and new edge's on front with new wheels all around.Aluminum brake nut,aluminum aft bulkhead,aluminum front hub carriers,Stage II performance head (blue),Venom racing fuel tubes,Servo saver in package,Front bumper in package(spares),blue ball cups all around(looks really neat.bout it),extra e-clips,body clips,antenna tubes,screws,body(I painted)among other things.I'll post more pics tomorrow.Dont feel like breaking the camera and such out.Gotta go to bed. but what should i ask for it?Oh,radio,reciever and servos are all stock.Cars in great shape though.
#8693
hey guys i picked up some masher 2000's yesterday and when i finaly went to rumem the motor was reving really high as the car was moving but it wasnt moving very fast so i tightned the rear diff and loosend it 1/8 turn and ran it again and still not much speed, is the clutch gone and if it is what kind of shoes would fit?
#8696
NY
yes, there is a blue padded ring, behind the spur. I would bet its glazed over, and not thick enough anymore, causing your spur to spin and rev the engine, but the top shaft isn't moving into the diff.
#8697
how do i change it and what part number is it if it is???, im thinking about changeing tha clutch, and rebuilding tha diff
#8699
NY
take off the slipper nut, and pull the spur gear and slipper plate off the top shaft. Then you will see the blue slipper pad.
#8700
RI
Scottywiles, i would like to thank you for giving me the advice to drill out the screws in the heatsink. If you had never told me that my truck would be shrap metal right now... My cluth broke and at the moment i instatntly thought oooooo shoot how am i gonna get the heat sink off to get the whole engine off... The only bad thing was i figured i would clean the engine while i had it out anyways, and the piston sleeve wouldnt come out so i got some pliers and pulled it out with them..., the only mistake i realised it kinda sortove chipped alittle bit at the top... So i have no clue if the motor will even run now..., over a stupid cluth. If it doesnt im going for the 0.S. .18 cv-rx
