plz anwser
plz anwser
hi,
i can get hold of a traxxas trx2.5 engine for a bargain price, i wnat too know will it fit the rush evo.
and if so what parts do i need.
pleeeeeeeeeeeeeeeeeeeeeaaaasssssssssssssssssssssss ssssssssseeeeeeeeeeeeeeeeeeeeeeeeeeeee answer quick!!
cheers
cheers
IL
RE: plz anwser
The mounting holes match so it is possible to put it in your car. But you are going to need a new header for your exhuast because the T-15 in your rush has a side exhast and the Traxxas 2.5 has a rear exhuast. Another thing that wont match up is the T-15 has a rotary carb adn the 2.5 has a slide. You can easily fit this with a switch of some stuff. Just ask someone else on how to redo your truck for a slide carb. Besides the few things that I have mentioned it seems it would fit. See if anyone else can come with anymore ideas.
Good Luck
Good Luck
OH
RE: plz anwser
I'm surprised that nobody brought up the crank issue.
is the engine a standard crank 2.5? if so, it'll drop in with nothing more than a little throttle linkage work and an exhaust manifold and the engine mounts.
if not, you're gonna spend waaaaaaaaaaaaaaaaay too much time tryin to piece crap together.
RE: plz anwser
ok give that idea up
cheers people
ps would u does us favour and vote for the hop up you reccon i should get on my rush evo. http://www.rcuniverse.com/forum/m_3259105/tm.htm
tnx
cheers people
tnx
