tottaly suck with no idea
when i start my nitro rustler right off the start it starts grabbing then lets go and grabs again.if u put your hand on my shocktower u feel HEAVY vibrations or juggin motaion. allmost likes ingachin and disengaging with the clutch im STUCK when i gun it, it stops or lift it off the ground it stops, its when its on the ground.
PA
RE: tottaly suck with no idea
i think you misplaced one of the t's in the thread topic. Pretty funny typo.
Are you saying that it engages the wheels intermittently at idle?
It sounds like your idle is up a bit too high and your clutch is engaging for a second and then disengaging. At least that is what it sounds like from my interpretation of your question. Try lowering the idle a hair and see if that helps. If it doesn't then check your clutch spring and shoes.
