Motorsaver Evader Info.. so you don't do what I did
CA
Well, I recentely found out that the 10mm carb version of the motorsaver will NOT fit the evader carb. It seems to need the 11mm.
On a side-note.. thank you to all that said they knew "for sure" that the 10mm version would fit... it's frustrating when people state things here as fact when they really have no clue or haven't even tried it themselves.
It wasn't a complete loss however, I simply attatched the motorsaver filter to the stock filter hose.
My Feedback: (12)
IL
RE: Motorsaver Evader Info.. so you don't do what I did
not sure what size the one I have is.. 10 or 11 mm, I do know that it's a ***** to get it on.. check it again dude.. try putting it partially on, then push down as you rotate it around, kind of like putting a tire on a rim..
