Turbo Questions
MN
Turbo Questions
i was just curious i have a stock trx 2.5 and i was wondering what a turbo would do to that and what would it cost.
Or what would be a good engine for the jato that would drop directly in and is affordable
thanks for all the help
CA
RE: Turbo Questions
get an os they have a wide spred of choices of horsepower and size. turbo engines are good for on road or high speed activities. your jato likes parking lots and streets right?
the os. or if you feel exotic get a novarossi or a picco...
GA
RE: Turbo Questions
Try a search as this has been discussed time and time again on this form. Forced air on small 2 cycle engines like we run where the intake and exhaust port are open at the same time does not work very well. All you do is waste fuel and there are a lot of better ways to spend your money to get more speed and performance. [8D]
I am sorry thought they were talking about turbo chargers![X(]
MN
RE: Turbo Questions
what does a fuel filter do and i run my jato where ever because i have street tires and off road tires, does the os engines drop in directly also i found a track where i live with lots of jumps turns
CA
RE: Turbo Questions
turbo is the type of plug that you can use if you engine is able to, and there is a porting method that is done to the crank of your engine to ease airflow thru your engine to produce moe power and quicker response.
MN
RE: Turbo Questions
but 2 of my questions still havent been answered what does a fuel filter do and what does os engines drop right in also are os engines expensive what are the price ranges
MN
RE: Turbo Questions
I can't answer any jato questions, as I haven't even seen one in person. The fuel filter though, serves two purposes really. First and of utmost importance, it filters any debris that may have gotten into your fuel or tank before it gets into the engine and destroys it, and secondly it stores a little bit of fuel in it for a few more seconds of running upsidedown. I have even heard of people putting two of them in for even more time.
Good luck
Good luck
MN
RE: Turbo Questions
wheres pennock
also does anyone know if a jato could pull a trailer i already have and idea on how to hook it up
i just need to know if it could do it, it would be made out of metal and wood
UT
RE: Turbo Questions
I doubt it....you gotta remember these little engines got no torque...you need torque for pulling...it's why we prefer 4 stroke nitro's on airplanes to swing larger props...ie..torque....if you start pulling things around with your jato it won't last long
QC, CANADA
RE: Turbo Questions
Just check this site [link=http://www.rbinnovations.com/catalog/index.php]RB INNOVATIONS[/link], they sell superchargers (not exactly turbos). this may give you a few answers. If they don't help performance, they sure look cool.
Just look at this picture:
UT
RE: Turbo Questions
ORIGINAL: montrealer
Looks cool is all it is...it does nothing to the engine at all they cannot prove it does either. $179 for something useless...can buy a better engine for that Besides even if it did work who would want a rubber band controlling fuel flow to the engine.
ND
RE: Turbo Questions
CA
RE: Turbo Questions
he would need to convert either the clutch to a 1/8th or monster truck or even just turn it into a big block jato o0o0o0o0 i had that big small block for the t maxx i think and my rc10gt just did back flips all day
GA
RE: Turbo Questions
Instead of wasting $179 on a worthless forced air induction system I spent $200 on something I know will work an OS.18TZ. Now all I have to do is finish beefing up the drive train before I install it.
