Pullstart to non pullstart
NJ
I know you need a backplate but i was wondering if you had to cut the starter crankshaft or if you could just remove it. I have no cutting tool so i was hoping i could just take it out.
There is a small shaft that protrudes out past the crank pin. This will need to be removed to clear the backplate.
If you decide to cut it, slide a piece of silicon fuel tubing over the crank pin to protect it.
