Threadlocker
GA
Hope it was blue! If you have a screw you cannot get lose try heat!
What I use is a very small butane torch like you get at Radio Shack. Heat the head up but you have to be careful.
http://www.radioshack.com/product.as...t%5Fid=64-2188
GA
ORIGINAL: econ909
new fire is bad, USE ELECTRICITY put two wires on it and the current will heat it.. lol
My Feedback: (12)
IL
ORIGINAL: SharkDiver
Ive been using the red..Is that bad?
shark
shark
red is permanent dude... you'll destroy it before the threadlocker gives in and lets loose..
you've gotta use blue!!!
Oops.[
I guess I better go get some blue.I only used it on my exhaust manifold because they kept come out.They do seem to be holding good tho.
Shark
]I guess I better go get some blue.I only used it on my exhaust manifold because they kept come out.They do seem to be holding good tho.
Shark
MA
For the red threadlocker you need to really heat up the part that has it to get it off, and if you use the green threadlocker (industrial strength) you are better of replacing that part. You can use hairdryer to melt the threadlocker, make sure you heat up the part evenly. Submerge it in hot water (as long as its not something that can be damaged with water) for a couple of minutes and try to take it of then.
FL
Oops.[
Shark
Oops.[
Shark
i dont know why they had to make it confusing
oyeah post #1200
GA
This is how it goes with the colors
Purple for small fasteners. I have not had much luck with this on my nitro vehicles.
Blue general purpose this is what I use and have the best luck on my nitro vehicles and this is what most use.
Red bearing retainer. Not for RC vehicles!
Green sleeve retainer. Sure not for RC vehicles!!!!!
I have been a motorcycle mechanic and machines for over 30 years. The only thing that will get loctie to break loose is heat on the stronger stuff. Like I said I use a REAL small torch. Some times I even have to use it on the blue.
