2.2 wheels for jato?!
PA
it depends on the tires. i just got a set of proline edges the other day that came with foam and I also picked up a set of speed paws, but they didn't come with foam. I think proline packages foam with their soft racing tires but leaves it out of the hard compound stiff sidewall tires.
damn it. I'm setting up my order right now... maybe I should just order them just in case..... [&:]
eh screw it, I'll go to my LHS if they dont come with them... I decided on dirt hawgz for the rear and pro-line m2 blades for the front, with the blue chrome clawz6-spoke wheels. [8D]
"If the wheels rub on the blue hex screw on the hub, replace the hex screw with a grub type set screw that will "sink" into the hub. This way you can run all 2.2 inch tires."
Could you get those screws from the hobby shop that would fit?
PA
Dirthawgs come with inserts, I am not sure that blades do but I would assume they would since they are soft racing front tires, and without foams they would collapse.
