Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Nitro Stadium Trucks
Reload this Page >
Engine dies when moderate throttle applied help please
RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Old 03-07-2006, 05:44 PM
tum_yeto
Default Engine dies when moderate throttle applied help please
I know this is a tuning issues but not sure if its to lean or too rich. After I get the truck runing when I start to apply any moderate amount of throttle the car sputters ever so slightly and dies my guess is its to rich but before I play with the needles I'd rather have somebody with experiance give me some info thanks
Old 03-07-2006, 06:24 PM
GTdirtracer
Default RE: Engine dies when moderate throttle applied help please
sounds like its rich, what car/motor is it, is it spitting gas, is it pullstart, bumpstart, roto, need more details but it sounds to me its rich bottom and top end
Old 03-07-2006, 09:29 PM
d2cs2mdw
Banned
My Feedback: (-1)
Way to rich, turn it counter clockwise 1/8 of a turn until you get the performance you want.
Old 03-07-2006, 09:45 PM
loadingpleasewait
loadingpleasewait's Avatar
Actually it's clockwise to lean it out.
Old 03-07-2006, 10:05 PM
tum_yeto
not really any fuel being spit maybe a little bit it Nitro star 18ss thanks for the info guys
Old 03-07-2006, 10:06 PM
tum_yeto
oh and its recently a rotostart
Old 03-07-2006, 10:50 PM
GTdirtracer
just wondering cause if it was pull you can feel the compression and if it flooded or semi flooded you can feel it but its rich and hopefully you have fixed it by now and already tearin it up
Old 03-09-2006, 01:34 AM
tum_yeto
The weather took a horrible turn so haven't been able to test the truck out I am hoping its just running too rich I know for sure its not flooded
Old 03-09-2006, 11:58 AM
nitrorcr182
If it idles fine and dies after your throtle it applied its a low end needle problem, you should play with that for a while. The low end needle is usually in the throtle barrol and should be set from the factory, but it sounds like that could be your problem. To adjust the low end you would need to start the truck and let it idle for a while, floor the throtel, if it dies immedieatly its too lean, if it sputters or revs then dies its too rich. Good luck!
Old 03-09-2006, 12:27 PM
ndexter
yeah turn it clockwise. once you have it to where it takes off like you want it to, you will have to adjust your idle (chances are the rpm's will be really high after adjustment). right now your engine is getting to much gas. I had the same problem with my 18ss. It tells you how to do this in your instructions on the page about the engine. good luck
Old 03-28-2006, 11:07 AM
jpep
I'm having same problems above with touching throttle, but my pipe is spitting gas. I can get the needles back close to factory setting (make needles flush), but there's no factory setting for idle screw. This is my first truck that've had for only 2 days and I need serious help
Old 03-28-2006, 11:14 PM
ryan_t888
ryan_t888's Avatar
Some manufactures say roughly a 1-2mm opening in the carb. Find the spot where your engine idles nicely and does not move the car with no brakes applied.
Ryan
