Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Nitro Stadium Trucks
 Repositioning of Batteries on Rusty >
RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Old 03-13-2006 | 11:44 PM
Default Repositioning of Batteries on Rusty
Hey Guys-
I've heard guys like to reposition the batteries on the Rustler for better control, move them forward and such. I was just wondering if anyone here has done so to their Rusty. If so, do you have any pictures for ideas or describe what you have exactly done.
Thank you-
Bry
Old 03-14-2006 | 05:59 AM
Default RE: Repositioning of Batteries on Rusty
If your running a hump pack (you realy should be if your not), place it under the front shock tower and zip tie it down. Tape works well too.
Old 03-14-2006 | 07:06 AM
well on a nitro sport you can reposition the standard battery pack under the chassis deck just in front of the tank but on a rusty it has to be on the top deck, so its far too high for good handling. just leave it where it is and make new shocktowers if your looking for better handling. if you want me to post a general description of the ones i had then just ask.
Dann
Old 03-14-2006 | 12:27 PM
Yeah, it's not a nitro sport, just a normal Rusty. Make new shock towers if I'm lookin' for better handling? I can make some? Yeah, dannthenitroman, please let me know how your shock towers are. Thanks, dann.
-Bry
Old 03-15-2006 | 01:26 AM
ok well the shocktowers on the stock rustler are too short, they make the truck sit high and have great 'bash-ability' but they allow too much downtravel when cornering, forcing the truck to become unsettled and lift tyres, and inevitably spin. my new towers were dremelled out of 3mm aluminum i bought from a local place called metal-land, the rear shock tower is about 10mm wider on each side and about a total 10mm taller. the front has an ok height, but i made mine 5mm taller and moved the shocks to 30mm apart, this allows MUCH less downtravel and a way more stable ride. they were designed by using the fibregalss traxxas towers as a template and then modifying from there on paper, then copying the design onto the aluminium sheet then dremeling it and drilling it . They will end up like the top of a rc10gt ft tower and a mounting setup that suits the rusty. yes this was designed off of my FT GT but only after i bought it, the designs were very similar before i bought the gt, the only change was to make the rear shock tower a little taller, and the shock mounting positions will need to be at the outermost hole on the rear arms for it to work and limit downtracel effectively. this setup allows (mainly the front as its practically flying 10 feet up stock lol) the truck to have a lot less downtravel and lower it woithout the need for extra short springs and fuel tube in the shocks. it also allows, unlike the short springs etc; full suspension travel but it will still be nice and low and 'tight' feeling. I have still not outdriven the rusty by more than a second on my local track with this setup. but the rusty had a LOT of mods.
Dann
Old 03-15-2006 | 11:28 AM
Thanks, dannthenitroman, I appreciate you sharin' your setup.[8D]
Old 03-16-2006 | 12:55 AM
thats fine, butif you want proof or your own ideas, you need to see how it acts when taking corners. if you have a video camera or a friend with one. set it on the ground on the racing surface and corner hard; right in front of it. as in, put it on th outside edge of a corner. that way you can see why is spins. with the rusty it is because it becomes way too offbalanced. my towers fixed it.
Dann
