Pull start and Tiger Drive problems
QC, CANADA
I have a problem with my OS 12 CV-X in a xxx-nt . The pull start continually slipped ( the one way bearing ), so I installed a Tiger Drive and still have the same problem. Impossible to start the engine.
Do you have any idea what might cause this? Should I roughen the start shaft on the engine with sand paper so that the one-way grips better? Any ideas?
Thank you!
Thank you!
NL, CANADA
Same problem on my Trx engine just take the bearing off and soak it in WD-40 or any other cleaning greases and then clean it out. This should work....worked for me.
