jato pullstart...
hi, my friend got a jato about a month ago and i just wondered if u can relpace the EZ start system on the stock engine with a pullstart. if so is it fairly easy and also which pullstart would be suitable.
cheerz, jon
cheerz, jon
GA
Being Traxxas makes a 2.5 with a pull starter I would think you could put one on it. Being I am not a Traxxas fan I cannot tell you where to get one but do recommend you check on there web site. I do not know your mechanical ability but as far as I am concerned putting on a pull starter would be easy.
GA
Glade to be able to help, as that is what these forms are all about. I see you are over seas so if you look on the link I sent you near the top right had corner is the manufactures number so when you try to order or fine one give them that number. Here it is just in case Manufacturer Stock#
5170
5170
