HELP!
Banned
My 3.3 just freaked up its piston. Is there any where where I can just buy the piston, and not the sleeve. This is freaked if i have to buy both for 80 BUCKS! And how do I prevent this from happening?
CT
They always come together as a set. At horizon hobby its on 47 bucks. How exactly did you "freak it up" http://www.horizonhobby.com/Products...ProdID=TRA5290
Banned
O ok well I was running it, and I dont know how to run the engine, or settings or w/e so i maxed out all screws (turinig to the right), and did a 3 and 1/2 turn the other way(the left). And the car finally stopped reving, and un reving like RUUUUUMMMMMMmmmmmmmmmmmRUUMMMMMMMmmmmmmmmRUMMMMMMM mmmm u get it. and also it stopped cutting out( I push the gas and the engine goes out.. So i began to run it and like 2 mins into it my engine revs like really high!!! And i push the gas and nonething happens, it just revs higher. So I pulled the fuel line to stop gas flow. And when i checked it, the piston was broke off. And dude how the frack do u put the pull start back on? When i put mines on I pull the string, and the gears and stuff dont move, but when i release it the gears and stuff move. GET IT? Thanx for all the help. I REALLY NEED IT!
My Feedback: (33)
O ok well I was running it, and I dont know how to run the engine, or settings I think you answered your problems in your first sentence . You will definetly need a new piston AND sleeve .
Banned
ONE WAY BEARING!!!!! Um what do u mean!?!?!?!?!?!?!??!! flip it? And is my engine under warrentee? Its like a month old, only had 10 or so tanks through it!
My Feedback: (33)
ORIGINAL: BigMike0001
My Feedback: (33)
ORIGINAL: Elite_Tux487
It almost sounds like the one way bearing on the pull start is on reverse. Try it the other way.
CT
When he was saying that he pulled on it and the gears didnt move and then when he released it they moved it sounded like the pull start was engaging when he released it like the one way bearing on the pull start was reversed.
Banned
How do I reverse it back? And I didnt know how to run it. So I red the instructions( lean out all the way and turn 3 and 1/2 turn richen) and I left idle and low speed the same. So really it was running fine, but it just snapped. They should replace it. It was clearly not my fault. And if some how it was, traxxas engined suck my ballz cux my thunder tiger .21 that came on my fusion NEVER did that!
CT
http://monster.traxxas.com/showthread.php?t=317580 It looks like you are not the only one in the boat you are in right now. I wonder if this is destined to happen to all the new 3.3s or if there are just a few lemons out there.
