RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Quick starter box question
Old 07-28-2006 | 11:19 PM
Default Quick starter box question
Hey, due to the fact that this is my first time really using a starter box...I wanted to ask if you need to prime the engine while using a stater box or if the starter takes care of getting the fuel to the carb. Thanks guys.
If it matters, it's a brand new engine...never has been touched except for installation.
Old 07-29-2006 | 03:21 AM
Default RE: Quick starter box question
Hi
As far as I know you do not have to prime the engine when you use a starter box. Once in a while you might have to if the engine is being a little stubborn and wont start, and if that happens all you have to do is plug the stinger of the exhaust pipe for a second or two.
Old 07-29-2006 | 09:18 AM
J_Bone's Avatar
Well, it's not so much the starter box but the engine it's self. The engine will draw fuel in but if the engine is brand new and you are going to break it in, you might want to manually prime the fuel to the carb or put a few drops of after run oil down the plug hole to help lubricate the piston and sleeve before the fuel gets there.
Old 07-29-2006 | 02:26 PM
Yeah I would definately prime the engine when using it on a new engine. Just cover the exhaust pipe and you should be fine. It also helps it start quicker then just sitting there not primming it. With most engines there is sufficent vacum from the engine is help draw the fuel in but it does take a little while for it to get up there.
Old 07-29-2006 | 04:18 PM
Thanks guys, yea, of course I'm going to break it in...I've just only had pullstarts/roto starts before...
Thanks again guys, and by the way, I've already put some AR oil in it...and more will be put in there
