Official Traxxas Nitro Sport Thread!!
#776
SK, CANADA
RE: Official Traxxas Nitro Sport Thread!!
ORIGINAL: Justspin
You will need an exhaust header as the 2.5r and 3.3 engines are rear exhaust and the pro .15 is side exhaust (I'm assuming you have a pro .15). You might also need a different exhaust hanger too. If your going to put a 2.5r in it you will need the conversion kit [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXDAJ8&P=M]found here[/link] and it comes with the parts you'll need for the exhaust.
ORIGINAL: humton
i recently bought a blue anodized pipe for my nitro sport. if i get a 2.5r for it will the pipe still fit. Thanks
#777
SK, CANADA
ORIGINAL: Justspin
Sounds like your engine is stuck at top dead center. Try taking out the glow plug and turn the flywheel by hand. If you can't turn it over then you might have seized the engine (which I doubt) Let us know what you find out.
ORIGINAL: humton
Today i was out driving my nitro sport. i have had it for awhile and it has always ran great and i even had it out last night and it was awesome. so today i fueled her up and started it. i was just slowly putterin around to warm up the engine. i did a couple high speed passes and suddenly it stalled. i went over to try and start it but nothing happened. all i could hear was a clicking sound. i replaced the glow plug but still the same problem. i replaced the battery in my ez starter and still nothing. did i blow somethin up or what. Thanks for your help
#778
ORIGINAL: humton
What does the nitro rustler have. it is a side exhaust and it has a 2.5.
ORIGINAL: Justspin
ORIGINAL: humton
Here's pics
#779
ORIGINAL: humton
ok so i tried it but still nothing. the piston does not move at all when i turn the flywheel or try to start it
ORIGINAL: Justspin
ORIGINAL: humton
#780
SK, CANADA
ORIGINAL: Justspin
The exhaust runs along the side of the car BUT it exits the rear of the engine.. on the pro .15 it exits on the side of the engine
Here's pics
ORIGINAL: humton
ORIGINAL: Justspin
ORIGINAL: humton
Here's pics
#782
SK, CANADA
ORIGINAL: Justspin
Yes, but one comes with the pro .15 to 2.5 conversion kit which you will need to put the 2.5 in your sport.
#783
ORIGINAL: humton
ok so through traxxas i can get the 85 dollar pro. 15 to 2.5r replacement plan and the 25 dollar conversion kit. then i put all that on my nitro sport but instead of the pipe it comes with i put the blue anodized one i have. that will work? and which would provide better performance the on in the conversion kit or the blue anodized one?
ORIGINAL: Justspin
#784
SK, CANADA
ORIGINAL: Justspin
correct. I'm not sure which pipe will work best, but you can easily try them both and find out for yourself. Also you will need a different ez-start as the pro .15 is different. If I was you though I'd either get a roto-start backplate or pull start and further save some weight and add more speed to your sport
ORIGINAL: humton
ORIGINAL: Justspin
#785
ORIGINAL: humton
well yeah i was thinking about that but i have heard some stories that you can never get it started with the pull start. that why i went to traxxas and the ez start
ORIGINAL: Justspin
ORIGINAL: humton
ORIGINAL: Justspin
#786
SK, CANADA
ORIGINAL: Justspin
I got rid of ez-start a long time ago and I'm very happy I did...
ORIGINAL: humton
ORIGINAL: Justspin
ORIGINAL: humton
ORIGINAL: Justspin
#787
I have a 3.3 in my sport with a pull-start. It takes me about 3 pulls to start it after I prime it. This way I only have to carry a glow starter in my pocket in case I kill the motor. I actually have found it's easier to use the pull start than the ez-start. I think this is because it's easier to flood the engine with the ez-start. This is my opinion and others have theirs. My second choice would be a roto start type system. These have the benefits of weight loss, but the draw-back of having to carry a starter or drill. I don't feel they turn the engine over fast enough to start it all the time and sometimes can be a pain. I just installed a big block in my Revo and I broke the pullstart after the first tank, so I'm going to a tiger drive system to start it since I already have a starter for it. Plus it's a ***** trying to pullstart a big block engine, lol. The TRX engines aren't that hard to pull.... Hope my ramblings have helped you a bit.
#788
SK, CANADA
ORIGINAL: Justspin
#789
ORIGINAL: humton
yeah they have thanks. with traxxas' erp can you exchange a pro.15 for a pro.15 or just pro.15 to a 2.5r
ORIGINAL: Justspin
#790
SK, CANADA
ORIGINAL: Justspin
yes, you can exchange pro .15 for any engine. Here's the correct link since I know it's hard to find http://www.traxxas.com/products/nitr...o_lifetime.htm
ORIGINAL: humton
ORIGINAL: Justspin
#791
ORIGINAL: humton
Is the pro.15 truly easy to tune and way easier to start than the 2.5r and 3.3. i am wonderin because i dont run this thing all day and dont have all day to tune a 3.3 or 2.5. to compared to the pro.15 are they really harder to tune and get started
ORIGINAL: Justspin
ORIGINAL: humton
ORIGINAL: Justspin
#792
SK, CANADA
ORIGINAL: Justspin
I think all TRX motors are easy to tune. I wouldn't say that any one of them is much easier or harder than the next. As far as starting I feel the same too. IMO Traxxas has some of the easiest engines to tune and start.
ORIGINAL: humton
ORIGINAL: Justspin
ORIGINAL: humton
ORIGINAL: Justspin
#793
To tell you the truth from my experience with my 3.3 is that I only have to tune it if the weather changes dramatically. I think it all depends on how much performance your needing out of the motor. I run mine rich so it will last longer, but by doing so I lose some power. Well in my sport which doesn't weigh much at all this motor is still too much for it, even running super rich. I've had to add a wheelie bar and bigger tires to keep it from flipping and burning the rubber off the smaller tires. Honestly if your not very experienced in driving it you will crash it in 5 seconds. I have learned my lesson a few times, haha. But I did love my pro .15 too and it was a heck of a motor.
#794
I just bought two nitro sports and a t-maxx 3.3 and i love 'em. I got the NS's two days ago and i've already added a carbon fiber shocktower, dirthawgs, changed the oil in my shocks. These are my first r/c's, i've spent my whole life building 1:1's and i can't get over how cool these are, i'm already an addict. I'm sure i'll be posting in here alot more often....
#795
ORIGINAL: mikey04hd
#796
SK, CANADA
well i ripped apart my pro.15 and i found the problem. the wrist pin and connecting rod came out of the head of the piston. i got parts from my local hobby shop and put her back together. i broke it in and i think that it runs better now than it ever has. Thanks for all your help guys.
#797
just curious but i was hoing that i could find some longer shock rods my rear is sitting lower then my frontend now for some strange reason even after completely rebuilding my shocks i even put new shocks on it and it still sits over an inch lower
#798
ORIGINAL: jsnnitro
#799
i already thought about that and checked it my shocks and everything are the same setup as on my other sport but yet this one is sitting lower in the rear same height in the front though
#800
ORIGINAL: jsnnitro
