RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Nitro MT wont start..help
Old 11-05-2006 | 07:26 PM
-Brian's Avatar
Default Nitro MT wont start..help
Checked the glow plug not flooded...what else can i check..how can i know if its getting fuel or not? Can i use starting fluid? If yes where do i spray it in?
Old 11-05-2006 | 11:19 PM
Default RE: Nitro MT wont start..help
No do not use starting fluid. Take the glow plug out and place your glow igniter on it and see if the glow plug ignites. If not then you either have a bad glow plug or you have a dead glow plug igniter battery. If they both work then try priming the engine. When trying to start it up place your fimger over the exhaust stinger and try and start it till ytou can phisically see fuel go through the fuel line. You shgould be able to see it, then just take your finger off and try and start it. Get back if these do not work
Old 11-06-2006 | 12:31 AM
46u's Avatar
46u
Little more information would help to help you. Is the truck new, have you ever had it started, is the fuel good, are you priming it, does the glow plug have fuel on it when you take it out. Is it a RTR what engine and yes check glow plug and the glow plug igniter?
Old 11-06-2006 | 10:33 AM
Exactly...have you changed needle settings, has the engine been out, have pressure/fuel line connections been crossed, are pressure or fuel lines kinked, is it equipped with a fuel filter, is the fuel filter plugged.....????????
Gotta ask the most questions you can 125cc......, if you're ever gonna learn to help someone... You can't ASSume the person asking the original question has vast experience or resources.... that's already helped you destroy one guys' engine, hasn't it?
ORIGINAL: 46u
Old 11-06-2006 | 05:30 PM
-Brian's Avatar
Ok so i now i can get the engine started but it just stalls after about 10 seconds..could this be because it is to rich?
Old 11-06-2006 | 07:19 PM
2-1/2 counter clockwise on the high end and flush with the collar on the low end should get you in a good spot, you may need to lean it out a little from there.
read this: http://www.*********.org/cars_eng-tuning.htm
Old 11-06-2006 | 11:11 PM
46u's Avatar
46u
I would like to help but you did not answer my questions which are in attempt to help you.
