no bump start?
ON, CANADA
Hey i was just wondering how do you start a bump start truck without a bump start? Is there another way to start the truck or is a bump start my only option?
ORIGINAL: alex_hockey
What kind of truck do you have?
--RCNZ
ON, CANADA
I just bought this rush evo off of ebay. Its in rough shape its a project for the winter i havent recieved it yet but he said it was a bump start only and i ddo not have one any other suggestions?
PA
You should be able to buy a starter box( aka bump starter) on ebay for cheap. I have seeen them go for as cheap as $30 and they probably go for cheaper then that. There a great buy. but you can get a pull start or something like that but you have to buy a new back plate a starter shaft and a pull start or whateve you want. So it might cost less in the end to just buy a starter box off ebay.
ON, CANADA
So i will need a pullstarter and a two way bearing right? THis engine is an HPI im pretty sure so any HPI pull starter for a .15 should work right?
That's where you would have to do a part number check against the older model Rush and the Newer Rush Evo. I'm not all too sure the FE15 uses the same one-way bearing as the T15 or the same backplate. That's a T15 engine, so look up the T15 parts. Or, if you have a little extra money to spend, you could save yourself the trouble of trying to workout the kinks of a used engine from ebay (could very well be trashed) and just buy a new engine with a pull start (solve the engine problems and start fresh).
A good cheap engine for a noob would be any O.S engine, or Dynamite 12spd is another good one.(The Dynamite is all I run, but I mod them first)
O.S. has the reputation for being solid, consistent, and reliable for a fair price.
The Dynamite doesn't have an over-abundance of power in stock form, and is a nice, reliable, easy to tune mill. Bonus on the Dynamite is the con-rod is knife-edged, and the ports on the sleeve are just begging to be modded. When done right, it gives it more punch in the mids, and plenty more revs.(when done wrong, it only costs about $40 to try again
