-=OFFICIAL HPI FIRESTORM THREAD=-
#4201
PA
RE: -=OFFICIAL HPI FIRESTORM THREAD=-
Oh dear - so I grabbed my camera and was letting my sister drive the FS so I could snap pics. Well, all is well until it rolled over upside down. This is not usually an issue, but then all of a sudden it stalled like bam, off. Usually it has no problem running upside down a little lean. So I ran over to pull start it, and the pull start was stuck! So I figured it was the string all bound up - nope. Then I figured ahh I had this issue before with the clutch maybe the clutch came apart, nope.
Turns out, after removing the cylinder head and pull start, something definitely got in the motor and scraped the crap out of the cylinder sleeve and piston. It could have been in the motor for a long time and just never mattered until the car was upside down like that, but anyway, done is done.
At a minimum I could probably replace the cylinder and piston and get back in it. I might replace the rod as well just cus. But damn, getting the cylinder sleeve out of the block was REALLY difficult. I tore the crap out of the sleeve and the block has some marks from twisting the sleeve out. I think it's ok, but yeah it was tough.
Should I rebuild it or put another engine in it? It ran so good! I am not a hardcore racer or anything I just like ripping around my yard - what do you guys suggest? This had maybe 20 tanks through it
#4203
PA
ORIGINAL: fasty
you can get a new motor from hpi for 65 buck if you sent your old 1 to them.
#4204
My Feedback: (14)
VA
ORIGINAL: fasty
Disjaukifa
#4205
ORIGINAL: disjaukifa
Has anyone here every done that through HPI? I was considering does that for my Firestorm seeing as the engine has a ton of us out of it and I figure it will need to be replaced soon.
Disjaukifa
ORIGINAL: fasty
Disjaukifa
Its on Tower for $130 (worth every penny)
http://www3.towerhobbies.com/cgi-bin...&I=LXGGP7&P=SM
#4206
My Feedback: (14)
VA
ORIGINAL: bushhiker
This would give you a good excuse to buy a OS CV-R I got that engine and man that thing has power. It blows the stock motor away (defently beats a Jato)
Disjaukifa
ORIGINAL: fasty
Disjaukifa
Its a nice looking engine but that is spending double for a new engine from HPI . . .
-Disjaukifa
#4207
ON, CANADA
You can get a new G3 for 75 on ebay plus shipping and then keep the old engine for parts. I am definitely thinking about an OS .18 CV-R or LRP for my storm and believe the money is worth it.
#4208
NC
I just installed the savage clutch with alumin shoes, upgraded digi servos,and a HPI hump pack.I have 2 quarts of fuel and I dont have to work tomorrow,cant wait.
#4209
ON, CANADA
Enjoy! I don't have to go to work tomorrow and will work in some RS4 and MT driving. Both are for troubleshooting reasons, though, but if I get what I want done with them I will get the storm out as well. Its been sitting clean and ready for weeks.
#4210
NC
Will do !! I have to get that switch guard picture up that I made,it turned out pretty cool. I'll see if my camera has batteries.......
#4211
IL
I have seen it done before and they are pretty handy. I hit a curb last week so hard going backwards that it actually flipped the switch off. Could have used it then
#4214
I just did some work on the cylinder liner of my G3 engine on my FS. What a difference it made in the top end. The high speed needle is about 1/16th out from flush now and I am using Omega 10% nitro. The hole shot on this truggy (out of the corners) is amazing now. All I have done is cut two fangs on each transfer port and two on the boost port, with some polishing on the cuts to smooth things out. Nothing short of amazing with such minute cuts.
#4215
NC
Any steering linkage upgrades ? Mine seems to have some play and I want something stronger/better....My main concerns are the components mounted inbetween the upper and lower deck just infront of the servo.....Thanks for any tips or ideas.
#4217
My Feedback: (14)
VA
Well I got my brake parts in today (hahah they flew off the other day because the e-clip was missing) and also the new painted HPI DSX body came in today also. I only bashed around the yard for one tank but )#*$# I had a blast. My wife and son where outside with me and it was just a whole lot of fun. After my run my wife then used her Traxxas Slash!!!
I got the Firestorm used from a friend, but I have basically gone through the whole truggy to make sure its good and ready to roll and today was the first day I got to really test it.
NOW the firestorm has not been tuned, I am running rich something crazy to the point that when I started the FS up, I would pull the trigger and the engine would cut off because it had to much nitro in it. I just got it to the point that it would stay on. I then proceed to bash around my yard, engine stalling only once and I think it was my fault. The new brakes worked amazingly well. It was nice to be able to just open the throttle up and then slam the brakes and not have to worry about hitting something.
I look forward to tuning it to get better performance and run time out of the Firestorm. So far this is my favorite nitro I have ever used.
If you want I can post pictures.
Thanks guys!!!
-Disjaukifa
Thanks guys!!!
-Disjaukifa
#4220
My Feedback: (14)
VA
Does anyone know some know a good aftermarket cooling head to keep the engine temperates low on the Firestorm. I'm curious to hear if anyone has found one that really helped lower their engine temps.
Disjaukifa
Disjaukifa
#4221
ON, CANADA
Are you having a hard time with temperatures? What kind of temperatures are you getting? I switched from 20 to 25% nitro and everything runs cooler - almost too cool.
#4222
My Feedback: (14)
VA
ORIGINAL: nitro-rob
Also I heard that to run cooler you would want to run a lower nitro like 16%, wouldn't running 25% make it run harder and hotter?
Disjaukifa
#4223
IL
Today is a good day fellow stormers. Yesterday i got the video of the big block storm beating a jato. This race was looks close, but I still win. There is another one that I need to edit down that I leaned out the low speed 1/4 turn and just blow him away by 15 feet at the end. There will be more to come soon with a rc 10 gt with a 18 tz in it. [link]http://www.youtube.com/watch?v=Mm6dLf-xhFk[/link]
#4224
CT
so how many of you have roto starts on your storms. my pullstart broke last time i went to use it and can't decide whether to replace the pullstart, get the rotostart, or get the tiger drive backplate and use a cordless drill. Any input would be nice.
#4225
ON, CANADA
I have a roto backplate and mostly use a drill instead of the HPI system. One another truck I have the pull start. I like both - the pull start is one less battery and system to prepare.
