Truck will not GO....
I recently purchased a Redcat 4wd truck, it ran fine the first couple of tanks of fuel, now it will not move when placed on the ground. The engine revs, if I pick it up the wheels move fine with throttle on... Any help?
PA
RE: Truck will not GO....
Before looking at the diff look at the slipper clutch. It may be loose and you will have to tighten the slipper nut if this is the case. It sounds like a slipper clutch problem.
PA
ORIGINAL: scott36
check to see if any of the drive shafts are broke or came out of there pockets.
