cvec exhaust system?
CA
so i was looking online at tower hobbies and noticed that the cvec exhaust systems for 1/10th trucks are discontinued..... anyone know why or whats up with that?...also anyone have suggestions for aftermarket exhaust?
Banned
46u
So name another .21 10th scale pipe then?????
There arnt any so how you can say its not good. They even have a changeable cone.
you can still get the pipes on ebay.
i belive they are bringing a new set of pipes out soon to replace them.
ORIGINAL: Banana Turbo
46u
46u
GA
46u
46u
OK if you are running a .21 then you can make many big block pipes work. I do not see where scales size will make that much difference. See it done all the time.
Banned
46u,
Well if you have a 10th scale touring with a .21 engine. No .21 pipe will fit without serious mods and possible welding.
But a 10th scale stadium truck is the same size as an 1/8th scale touring so its no worrys. But still if you have rear exhasut manifold and mounting. No .21 pipe will work without modifacations.
GA
Here is a MT2, 1/10 stadium truck with a big block Savage 25 engine with a stock big block Savage 25 exhaust with little or no modifications.
http://www.rcuniverse.com/forum/m_5176805/tm.htm
All so this is the stadium truck forum not touring car so why are you talking touring car. I have seen plenty of stadium trucks with big blocks and stock or near stock exhaust and proof is in the above link. [X(]
