RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Nitro Evader Problems
Old 02-27-2007 | 06:28 PM
Default Nitro Evader Problems
Ok. so heres the deal. I have a nitro evader st that i barely ran. (about 1/2 gallon of nitro through it). Unknown to me the screws on the pipe came loose and burnt of the gasket and it ran like crap if at all. I thought it was the tuning (dumb mistake). So to make a long story short i ran it too lean to try to get it to run and now have worn doen the piston sleeve and have lost compression. Now i am in the predicament of whether i replace the sleeve/piston/ con. rod or buy a new engine. I could do the repair myself but i dont want to waste the money if the nickel plated sleeve is just going to go out again. Which would be the better way to go?
thanks
Mike
Old 02-27-2007 | 06:44 PM
scottywilkes's Avatar
Default RE: Nitro Evader Problems
do u still have the receipt? If so the engine has a 2 year warranty, they will replace or rebuild for free, u just have to pay to ship it there.
Old 02-27-2007 | 06:57 PM
I got it so long ago...it might have been two years by now. I dont think i have the receipt.
Old 02-27-2007 | 07:23 PM
u should get a new engine the nickel platind is crap mine only lasted 1 gallon each time i rebuilt it
Old 02-27-2007 | 07:25 PM
would you sugest the os cvrx .18? or something else?
Old 02-27-2007 | 07:27 PM
the OS18cvrx is no doubt the best drop in engine for the nitro evader, but u will have to get a alloy diff gear and a few plastic idler gears. Dont get all alloy, cause they will just wear each other out, and its nice to have a cheap weak point in the tranny
Old 02-27-2007 | 07:29 PM
the .18cvrx is a good engine it drops right in tons of power jus got one a few days ago
Old 02-27-2007 | 07:33 PM
so the os 18 cvrx is about $110 on tower...how much would i look at spending on the idlers and alloy differential gear?
Old 02-27-2007 | 07:44 PM
i got my diff gear for $20 can so maybe $15 not sure price for the plastic idlers tho igot steel one was like $25
Old 02-27-2007 | 08:19 PM
if i were you id buy a new engine, i mean id dont know you very well, but i think you may have a friend that is giving you a team losi xxx-nt adam drake so i would just spend the money on an engine for that and race that
Old 03-19-2009 | 03:48 AM
hi im new here and i have a nitro evader and i love the truck and i have some questions i was wondering if u guys gould help.
wen it is running some times it will die and the pull start wont pull ???
and how big is stock gass tank i went 2 the hobby shop and they sed my tank is not the stock tank and wont 2 know what tank it is but idk i bot the truck off ebay $80 it was used (pull problem is my folt dident do it wen i first got it)
Old 03-19-2009 | 03:31 PM
here r pics of my evader with the bigger tank
ID:	1161309   Click image for larger version
ID:	1161310   Click image for larger version
ID:	1161311   Click image for larger version
