how do i fit a clutch spring
hello every 1 i am quite new to the rc sean but have striped the car down and found that its the clutch spring the has snaped so i am needing a bit of help on how to figur out how to put it back on, my car is a firestorm so if anybody has any idea or diagrams or even vids on how it goes on i would be greatful i am guessting it just goes round the shoes but i would not no, i also thinking it is probly the same as any other clutch on a rc car
IN
RE: how do i fit a clutch spring
Yep, you have it right. Take your shoes and position them so that they make a circle with the holes opposite each other. You then wrap the spring around them like that, and push it onto the flywheel. A little daunting and tedious, yes, but you'll get the hang of it.
