Firestorm Help
CA
Every time I hit the brakes the engine shut off. I messed with the clutch for the past week, The carb stays 1mm open when I hit the brake but it still shuts off. What could be wrong?
Sounds like your to the point of frustration[&:] First replace the glow plug and if that doesn't work. Reset all the needles to the stock settings and retune starting with the HSN and work your way back[&o]
I had the exact same problem with my FS its just about tuning it right and making sure the carb isnt fully closing ! havent had any problems with the clutch so it cant be that
good luck is all i can say hehe
CA
yeah i'm pretty much at the point where I'm ready to smash this thing. I took apart the carb and the clutch and redid everything. I even set the needles back except the LSN because I can't get the engine out because I stripped the screw. It finally doesn't shut off the engine when I brake.
But now when I start the truck up it doesn't stay in neutral it takes off running. ***?
I've been to 3 LHS and everyone there are a bunch of idiots!
CA
I think I got it, gonna take it for a test run and then test the temp. Does anyone know if HPI does repairs or tuning? I'm tired of messing with this thing.
hi im a beginer and im having trouble with the cluth "I think" i can start it but have to give it a push to ceap it going?
I cant get it to idol ithier and need help to figuier out what is wrong.
