clutch problem
clutch problem
I just put the flywheel and clutch from my .15 onto my trx 2.5 and it seemed fine. Spinning the flywheel by hand would make the engine turn over. After I mounted it in my Sport I hooked up the EZ start and tried to start it. Now if I spin the flywheel by hand it doesn't move the piston up or down and it is hard to turn the clutch bell it wants to turn the big gear also. If I try starting it now the wheels continue to spin while it is turning over. Anybody know why the flywheel will not turn the motor over?
