Car refueling
Car refueling
Hi just a quicky,
Is it ok if i re-fuel the car while it is still running?
Or do i have to run the tank dry and re-fuel after the engine has cooled?
GA
RE: Car refueling
Believe when others and I are racing and pit we sure do not stop the engine. Normally when pitting you get fuel all over the vehicle as you grab the fuel bottle open the lid and squeeze just like any racing you want to be back on the track as soon as possible.
RE: Car refueling
ORIGINAL: 46u
so you are trying to tell him its ok to pour fuel all over a hot engine and pipe?
NC
RE: Car refueling
A little fuel wont hurt, and to be honest the combustion is much hotter than what the engine temp is. Therefore it wont ignite like everybody is saying it will. Regardless, if your not in a race, take your time doing it and try not waste much. Afterall isn't the cheapest stuff, lol.
But 46 is right, in a race that stuff is just thrown in there. Throw the truck on the starter box, to get the wheels off the ground. The driver is reving the motor to keep it alive and you grab the zip tie, squeeze the crap out the fuel bottle until fuel flows over and throw the truck back out on the track.... its a rush.
-bryan
-bryan
RE: Car refueling
i race 1/8 onroad, i know what happens when you refuel during a race but i wouldnt make it sound like its ok to do it, its not such a smart idea to pour fuel all over a hot engine and pipe, you never know, its not worth taking the chance if you dont have to.
GA
RE: Car refueling
ORIGINAL: ehroof
RE: Car refueling
Just so you all know the flash point for nitro fuels are 97 degrees. Not very high adn it does not need air to burn. On the other hand I have never heard of someones car or truck getting burned up because of a fuel spill. When you race you spill. I would not worry about fires.
RE: Car refueling
Both Nitromethane and Methanol need oxygen or another oxidant to burn. Neither will burn underwater or in a vacuum. Nitrous Oxide however, does not, as when heated to 1600*C, it will release the oxygen needed to 'flash' due to the 'oxide' component of the compound.
Furthermore, the flash point (defined as the lowest temperature a substance will burn, WITH an ignition source) of nitromethane is 37*C, therefore, pure nitromethane cannot even be lit with a spark below this temperature. The flashpoint of our fuel is brought way down by the methanol content which has a flashpoint of 11*C, therefore, on a very cold day, you cannot ignite our fuel even with a spark. The temperature at which nitromethane will SELF-COMBUST (ie ignite without an ignition source) is a whopping 425*C. The same for pure methanol is only a slightly lower 385*C.
GA
RE: Car refueling
All so store it in a dark place climate controlled low humidity. I have keep fuel for as long as 1-½ years stored properly. If I have a bottle open with some of the fuel gone I squeeze the bottle to try and get as much of the air out as I can then put the cab on.
GA
RE: Car refueling
ORIGINAL: zeddfirstwizard
Dont store it use it!!!!!!!!!!!!!!!!!!!!!
Well when your sponsor sends you 2 cases it takes a while to use it so you will have to store it for a little while anyhow.
