RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
UH OH HELP!!!
Old 11-29-2007 | 08:22 PM
Default UH OH HELP!!!
ok i whent to break in my rustler's 2.5 and i got about 5 minutes into it but and when i have it just sitting idle it died after a minutes also i was wondering how many starts do you get with the ez start cause im haveing problems with it , it doesnt seem to work for more than 1-3 starts. i was wondering if it was my battery or what? and what do i need to do for my rusty.
i only got 4-5 mins into tank 1 of break in -.-
Old 11-29-2007 | 08:25 PM
bigairlife's Avatar
Default RE: UH OH HELP!!!
How many miliamps is your battery? 1600, 2000, 3000?
Old 11-29-2007 | 08:28 PM
it is becaue is so rich, turn up the idle screw, or adjust the throttle trim on the radio...the ez start problem sounds like your battery is the culprit
Old 11-29-2007 | 08:33 PM
kool thanks guys what should i set my throttle trim on my radio at
and my batt is a 1500 how many miliamps should i get.
Old 11-29-2007 | 08:38 PM
that should work, its what i use, and i get a decent amount of starts with a cheap wall charger....if you have a glo starter, use that instead of the blue ez start cord....you will get a ton more starts then..
as for the throttle trim, turn it all the way up, then cut it back slowly until it is enough to run, but not roll forward
Old 11-29-2007 | 08:41 PM
bigairlife's Avatar
1500 should be fins, but if u want a new one, get a 3000 MAH.
Old 11-29-2007 | 08:42 PM
ya a 1500 battery will get u some starts
i got plenty lol but use the glo ignitor trick
Old 11-29-2007 | 09:28 PM
i charge my battery but no matter what i do it doesnt seem like enough it doesnt even start up my car to clean the motor. it seems like the battery is burnd out or somthing and when i was breaking it in it would rev the motor at 1/4 throttle but it wouldnt move i would have to pull it to 1/2 throttle to move it, what do i do for that and what the hell is wrong with this thing lol its brand new.
Old 11-29-2007 | 09:34 PM
its just because its rich...my 3.3 was the same way...once it starts to loosen up, it will be fine
ditch the bulky ez start and get a pull or bump start.
Old 11-29-2007 | 09:36 PM
if you do that, id recommend a bump box..way easier for break in than a pull start
Old 11-29-2007 | 11:51 PM
whats up with my ez start it lights up both lights but nothing happens i think its the battery cause my car started fine at first before my battery was possibly over charged. my dad charged it so much that it was almost to hot to hold and thats a BIG no no. so what do you all think should i get a new battery?.
Also how many starts do you all usually get out of your ez starts? just out of curiosity. and how many miliamps can the ez start handel i had 1500 but that seems like crap. -.-
Old 11-30-2007 | 01:34 AM
Elite_Tux487's Avatar
You probably built up memory on the battery...and overcharged it...To lengthen the life of the battery...always fully discharge the battery before recharging.....With my friends 4-tec...we got probably 15 starts or so on one charge of the battery while using a separate glow igniter.
Old 11-30-2007 | 01:47 PM
i tried it this morning and she just started up as nothing happend i think the battery had time to relax over night also with my problem of the rustler not moving at 1/4 throttle would that be the low speed needle that i need to adjust and do i need to lean or richen the mixture cause i have alot of exaust fumes coming out when she starts up.
Old 11-30-2007 | 02:50 PM
IF you got raw fuel spitting out when you give it throttle...then your high speed needle is too rich....At 1/4 throttle..is the engine revving up and its not moving or is it just like bogging down?
Old 11-30-2007 | 03:21 PM
IT'S SUPPOSED TO BE THAT WAY FOR BREAK IN
Old 11-30-2007 | 03:35 PM
it revs up when i do 1/4 throttle
oh and i was adjusting the throttle trim thinking maybe it was that and then it died. (so any info on where i should set it would be great)
also left is richen and right is lean am i correct also what does it sound like i need to do with it lean it right?
and just so im clear lean means add air and richen means less air more fuel am i right?
Old 11-30-2007 | 03:41 PM
as it should, but its very sluggish..right?...and it takes a little bit more than what you would think to get it moving.....its just part of breaking it in....very sluggish.......but do not lean it out, it moght run a little better, but will not have enough lubrication.......
what type of plug are you running
Old 11-30-2007 | 03:57 PM
just the stock glow plug it came with i got some heavy duty glow's that i baught if those work better.
Old 11-30-2007 | 04:00 PM
try the new plugs...they should be hot ones
Old 11-30-2007 | 04:06 PM
k will do.
Old 11-30-2007 | 05:41 PM
if yall dont mind post up some info on what im supposed to do
Old 11-30-2007 | 05:52 PM
i read my trouble shooting in my manual and it says that the fuel mixture is probably to rich so should i lean the mixture and thats to the right (clock wise) am i correct?
