RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
JATO 3.3 Missing Front End!!
Old 04-06-2008 | 09:26 PM
Default JATO 3.3 Missing Front End!!
Hello, I was given today a jato 3.3 but it dosent have a front end. Can anyone please give me a parts list of what i need and estimate how much money it will take to get it back running?
Old 04-06-2008 | 09:38 PM
Chris_RC's Avatar
Default RE: JATO 3.3 Missing Front End!!
I don't know about the Jato, but on ebay I get XXX-NT fronts and rear ends for about $15-20 shipped. So take a peak on ebay, see what they got.
Old 04-07-2008 | 12:09 AM
Nick2618's Avatar
Here is all the parts you need for the front and how to put them together...
http://www.traxxas.com/products/nitr...xpld-front.pdf
Also ebay is the CHEAPEST place to get all jato parts...
Old 04-07-2008 | 12:13 AM
MiamizFinest's Avatar
it strip the motro down first and look everything over since looking at the clutch bell and all the metal screws it looks liek it has alot of rust on it, lord knows how the motor internals are
Old 04-07-2008 | 12:15 AM
Nick2618's Avatar
ORIGINAL: MiamizFinest
Good thinking. Also as it is you can start it up and make sure the engine runs good.
Old 04-07-2008 | 06:42 PM
ORIGINAL: Nick2618
Thanks but the link dosent work
Old 04-07-2008 | 07:55 PM
Do you guys think rust remover will get it off?
Old 04-07-2008 | 08:33 PM
yeah it should but first try using some WD-40, Be carefull thats how i got my car on fire But nothing bad happened so just wait like 10 mins before you start the engine
Old 04-07-2008 | 09:04 PM
CAN SOME ONE PLEASE TELL ME HOW TO GET THE GEARS OFF THE jato..i took the 3 screws and notes and spring off but it wont come off!!. Also how to i remove the E clip on the other gear?
Old 04-07-2008 | 09:20 PM
for the biger gear dont be afraid to use some force but it should be easy to take it of at least mine is maby the rust is like glued it together, so use some force. For the e clip use the screw driver
Old 04-07-2008 | 09:23 PM
Ok, that is the most rust I have seen on a rc car. But back on subject you will need a [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXKME1&P=Z]bulk head[/link], [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXKMF4&P=Z]bell crank[/link], I think you will need [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXKMF3&P=Z]this[/link] for the bell crank, [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXKME2&P=Z]stock a arms[/link] or [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXLXB2&P=Z]rpm a arms (black)[/link], [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXKME6&P=Z]stock bumper[/link] or [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXMAH7&P=Z]rpm bumper (black)[/link], [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXKMF0&P=Z]stock upper turnbuckles[/link] or [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXSCT9&P=Z]lunsford turnbuckle set[/link] or my favorite [link=http://www.jdcarbon.com/carbon-fiber/perrc/jato/]jd carbon turnbuckles[/link] or the [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXKML7&P=Z]traxxas red turnbuckle kit[/link] lower turnbuckles [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXKME9&P=Z]stock lower turnbuckles[/link], [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXSCT9&P=Z]lunsford turnbuckle kit[/link] or [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXKML7&P=Z]traxxas red turnbuckle kit[/link], or [link=http://www.jdcarbon.com/carbon-fiber/perrc/jato/]jd carbon turnbuckle kit[/link], you will need [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXKME3&P=Z]caster and steering blocks[/link], [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXKLZ6&P=Z]blue screws for pins[/link], [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXKMD2&P=Z]pins[/link] or [link=http://www.jdcarbon.com/carbon-fiber/perrc/jato/]jd carbon pins[/link], [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXKME8&P=Z]spindles[/link] [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXKMA4&P=Z]4 wheel berrings[/link], [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXKMA5&P=Z]wheel spacers[/link], [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXKMC9&P=Z]shock tower[/link], [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXKMC5&P=Z]front body posts[/link], [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXKMH2&P=Z]stock shocks[/link] or [link=http://cgi.ebay.com/NEW-Traxxas-REVO-COMPLETE-Aluminum-GTR-Shocks-JATO_W0QQitemZ310037565660QQihZ021QQcategoryZ44028 QQssPageNameZWDVWQQrdZ1QQcmdZViewItem]revo shocks[/link] but you will want to put the jato pistons in, [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXKMB0&P=Z]stock spring[/link] or your choice in springs, and wheels of your choice. Oh yea you might want to get another spur, clutch bell, and a [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXSFL2&P=Z]screw kit[/link] and replace all your rusted parts. Man, that took me atleast a half hour. Oh whell hopefully it is worth it to you.
Old 04-07-2008 | 09:29 PM
Nick2618's Avatar
ORIGINAL: icecube0045
ORIGINAL: Nick2618
hmm it works for me. If you have a slow internet connection it may take a few mins its a pdf file that is a couple MB's i think OR you might not gave adobe reader??? To find it just go to traxxas website and click models and find the jato. Then under the jato link there is exploded views. Just look in there and you will see the front end view listed.
Old 04-07-2008 | 10:43 PM
Thanks a lot guys...
Is the flywheel on the bottom of the jato suppose 2 b able to move? cuz mine cant
Old 04-07-2008 | 10:45 PM
well i can turn mines with finger but when turning the wheels its not turinig
Old 04-07-2008 | 10:48 PM
Nick2618's Avatar
If you cant turn it by hand that is good because that means it has a lot of comprasion, UNLESS it also dose not turn when u use the ezay start then your engine is jammed up and stuck in top dead center. You can take a flat screw driver and kinda move it but if you know nothign about this engine you should really tear it down and make sure everyhting in it is good.
Old 04-07-2008 | 11:00 PM
take a flat blade screw driver and try to turn your fly wheel with that. If it moves it is good if it doesn't whell your engine is toast.
Old 04-07-2008 | 11:27 PM
wth the flat head it is moving A LITTLE but thats it
Old 04-08-2008 | 01:00 AM
what happened to it?
Old 04-08-2008 | 02:51 AM
to wat?
Old 04-08-2008 | 03:03 PM
I would just use that truck for spare parts and just buy a new Jato.
Old 04-08-2008 | 03:08 PM
ORIGINAL: j8to33
ok i have not seen so many hyperlinks in one post in my life[X(] and for the engine dude i would just replace the whole thing including clutch bell and slipper.
Old 04-08-2008 | 03:40 PM
so wait whats wrong with my flywheel ??? i can ture it with my finger but it doesnt turn when i turn the wheels ???
Old 04-08-2008 | 03:46 PM
yeah your flywheel sould not turn when you move the wheels.but if you can still move it with your finger then your alright
Old 04-08-2008 | 03:55 PM
If I replace the engine could I put any engine on it and would it work with the ez start? If so what would be the best motor for it?
Old 04-08-2008 | 04:01 PM
a little of that is your choice.you could either replace the stock engine with a new trx 3.3 or you could use O.S engines.......you can use the easy start with any trx engine and i'm not fully sure but i think O.S has a easy start backplate engine versions
