Official Traxxas Jato 3.3 Thread
#476
RE: Official Traxxas Jato 3.3 Thread
ORIGINAL: nitrorevo
I think I said about 60mph, and you should hit that after complete breakin. Try the lower gearing like I mentioed. It may allow the engine to wind out more, and actually give better top end. The 30% will help as well.
#478
ORIGINAL: jbrobertsonjr
well i have my first problem with the jato i run up my street after warm up runs fine pulls the wheels then after the second tank of fuel it like one minute run like heck then run bad as if it can not get in the rpms ,if you ease it around for a while it runs strong again as if nothing is wrong help i am stunned one minute it runs good then runs bad.
#479
Jbrobertsonjr I'm also having a bit of a hard time understanding you. But I think you said that on the second tank it bogs down for awhile. If you keep the car running while your putting fuel in it you will have unburnt fuel in the motor. Then when your done refilling and you go to take off the motor bogs. Try leaning out the low speed needle a bit and you should not have the problem again. I hope that's what you wwere talking about.
#480
TN
one minute its starving for fuel wont hardly run you can slow down and idle it around then try it again and it runs fine thanks guys.
#481
TN
i want to run blue thunder 30% in my jato 3.3 , i broke the motor in on 20 % fuel , will i have to change anything , i heard about some shims , i know i will have to adjust the carb but what else . and thanks for all the help.[>:]
#482
NC
ORIGINAL: ajk2649
Yeah know I have run into a new problem. One of the engine mount bolts stripped and I just cant seem 2 get it off 2 replace it. The problem that brings is I cant use other gearing cuz I cant move the engine mount 2 adjust my gear mesh. anyone have any ideas on how 2 get the bolt out?
ORIGINAL: nitrorevo
http://www.4grabit.com/Default.asp?g...dEylVSw&bhcp=1
#484
KS
Yo guys, i haven't been on 4 awhile, but i got my brake working perfect and everything seems fine, so its time for some closer tuning.
When i was running it today, it worked a-OK for about eight minutes, but then the engine bogged down a whole lot and i couldn't crank it all of the way up to top speed. i think that i may have been running it a bit hot and i did that weird drop of water on the engine head thing and it boiled off in about 4-5 seconds. does anybody have any ideas?
#485
ORIGINAL: rcphanatik
#486
#487
Sound like you over heated. You can also tell your over heating by the idle of the engine. If it becomes a little high pitch and tends to rev uniform but high then you definantly over heated. Just try to richen the HSN a bit and you should be ok. I know the 3.3 is a little tricky thats why I went to an OS motor. You pretty much tune once and it will hold a tune for almost an entire gallon of nitro. Good Luck.
#489
TN
well i fixed my problem ,the fuel tank was not sealing when you fuel it with the body on ,i have to make sure the lid is all the way closed, you guys have not talked to me in a while i hope i have not made you all mad at me. thanks for all the help.
#490
#491
ORIGINAL: nitrorevo
Local hardware store $20 bucks. I shim screw was stripped in my shaft and I couldn't get the CB off. After 2hrs trying everything. I picked up this set from hardware store. 2 min. and done.
ORIGINAL: ajk2649
ORIGINAL: nitrorevo
#492
guys i know this is a really inaccurate way of measuring speed, but i have to know how fast my stock jato 3.3 is going!! please someone!!
here is the link: http://www.youtube.com/watch?v=2jl9R...e=channel_page
thanks for any reply!
#493
ORIGINAL: Nitro-4 Tec 3.3
#494
Well just got some new MIP CVD's for my Jato and boy oh boy do the look nice. No more broken plastic CVD's. Why would they put plastic ones on the Jato I just don't get it. They did work pretty good though until I started adding more power. Any ways I have not run it yet cuz I gotta take the truck apart and clean it. But MIP's have worked great on My RC10GT's and have lasted for years.
#495
ORIGINAL: quietnas1
I would say about 60mph on some of your faster runs. I would rocomend tightning the slipper clutch a little you have way to much slipage.
#496
I got to agree with ajk. I was going by what Jato does and trying to judge yours. I don't have a Radar gun yet but my phone has a GPS tracker with a MPH gaudge that records the max speed. I strapped on the phone to the Jato and got a best I got was 68 mph and it was leaned out quite a bit but not to much. I'm sure I could have gotten more but I don't like to run my motors way to lean especially when I run my car every day. If anyone can give me some tips on how to post on youtube. I would love to post just don't know how to.
#498
ORIGINAL: quietnas1
#499
thanks for all the replys guys!!! but i have a problem, if i lean it 1/8 of a turn the idle gets higher and i dont know why, that is why i dont run it leaner is this normal??
thanks, and my best regards!!
#500
Well I know if you lean out the LSN the idle will go up a bit but leaning out your HSN should not have anything to do at all with the idle. I know the 3.3 can be a bit tricky. I had gotten used to it after a bit but you cannot go wrong with an OS motor.
