Official RC10GT Thread
#1601
RE: Official RC10GT Thread
hi there, at first sorry for my english, i am from austria.
next week i will get a rc10 gt factory team and i want to know what a type of engine i had to buy?
i do not wanna race with the car, just go for jumps and i like to go for speed. what do you think about this motor?
LRPZ.12R TEAM SPEC.2
horsepowers: 1.58
3 000 - 42 000 U/min
is this good enough or is this engine to samll.
is a big block better or is this ok?
thanks for answeres
mihael
horsepowers: 1.58
thanks for answeres
mihael
#1605
AZ
ORIGINAL: mihaelbencek
horsepowers: 1.58
thanks for answeres
mihael
horsepowers: 1.58
thanks for answeres
mihael
#1606
Hahaha, yes he means it is very good look,
it is very good , that engine will have a lot of power. excellent choice.
ask questions whenever you want here, we are all happy to help.
Dann
Dann
#1607
CA
hey guys, i was thinking about getting an rc10gt. are there any major weak points of the truck? everyone seems to love it... do you think i would be able to re-gear the clutch bell and spur to get around 40 without loosing too much low end on the stock engine?
#1608
TX
Big question for everybody:
What are the best rear shocks I should put on my RC10GT to replace the old WORN OUT AS HELL stockers? Should I go with Evader shocks, Losi XXX shocks, some hopup RC10 shocks? Just tell me whats best for landing pretty big jumps on the racetrack with my heavy alum truck. Thanks
#1610
TX
ORIGINAL: unclezesta
i dont know about the others, but the evader ones are pretty cool.
#1611
CA
actually, my friend uses them. he hasnt had any problems at all. theyre really smooth moving and you can get a bunch of different spring strengths for them.
#1612
hi. thank you so much for your answeres. ok today i will buy this engine and i had to look for a good manifold.
what is with the shocks from the rc10gt factory tram kit, good shocks, what are the good things and what are tehe bad things at the rc10gt factory team kit is there a bad thing taht i had to change in the beginning to a ho up part?
bye mihael
i know my english is terrible but try to write german, hahaha
bye mihael
#1615
AZ
The brakes are $32 from Crescenzi Racing(see my signature for link). The RX box is $7 and MIP clutch is $10
If you bash a lot you can get RPM a-arms, but if your going to race, just keep the stock ones.
The stock engine might get you above 40 if you re-gear it, but will loose a lot of bottom end. I would say get a new motor if that is your option.
#1616
AZ
ORIGINAL: pilotwings119
I would just buy all new shocks or rebuild the old ones. I had a few leaking issues and I tried using the green slim and that didn't work either. After inspecting them, I had a nic in my shock shaft that was tearing the o-rings. After I replaced the shafts, new o-ring kit and just using shock oil on the threads, they never leaked again.
#1618
in the back where the reciever connection is.... if tahts wat u mean. just zip tie it so it wont fall out
__________________________________________________ __________
hey guys today im gonna finally break in my rc10 since its spanking new. i have the rtr plus, is the high speed adjustment set for the first
2 tanks? or do i have to turn it 1/4th from the stock setting
#1619
TX
ORIGINAL: J_Bone
The stock ones are good! If you put different manufacture shocks on your GT, you will change the dampening and not get a balanced setup. Don't do it!! Especially Duratrax..
What are the threaded shocks?
I have a set of Team Bluestar threaded shocks, but they all leak too!! There's a hole in the top of each one, and all the oil just squirts out of them.
I'm already bidding on a good-looking set of [link=http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=6053936003&ssPageName=STRK:MEBI:IT]Evader shocks[/link]. If I find (or you guys show me) a better set to either bid on or buy that are roughly the same price, I can retract my bid on that auction.
#1621
CT
Ok a while back I had a problem with my ae.15 not being able to get fuel to the carb, I had it sitting around for a while then one day i decieded to rebuild the carb I did that cleaned it out and made sure there were no blockages. Today when I went to try it for the first time since the rebuild I still can't get fuel to the carb. If i remove the line going to the carb fuel will start coming out of the tubing so it does have pressure going to it. Also if I pour a few drops of fuel directly into the carb under the air filter the engine starts right up but doesn't draw anyfuel up the tubing. Im at my wits end with this finky engine. I was weighing the choice of just getting an os .18 but the ae.15 has only about a quart and a half of fuel through it/ [] Thanks if any one can help
#1623
i had this problem with my savage the fule wasnt going in, then i discoverd a leak. so i jus cut the part with the leak off and the fuel was flowing.
#1624
elite try taking the tube off the muffler and blow on it , should get fuel flow to carb, if not u should find a leak that way just becareful not to get a mouthfull, might be the seal(oring) to the tank lid
#1625
CT
I did this under water when i was rebuilding the carb I took the fuel tank and the tubing under water and plugged one end of the tubing up and blew into it and found no leaks and someone told me to replace the tubing and I did that.
