Official RC10GT Thread
#1576
AZ
RE: Official RC10GT Thread
ORIGINAL: gkcx
Anybody know if Associated is ever going to come out with a new GT design? It's been around for a long time and hasnt changed. I know it's a good design but something new would be nice.
ORIGINAL: testuserdann
Yeh its coming. its got a top deck etc, kinda like a losi but MUCH more GT like.
Dann
Dann
#1580
hey yo RC10GT experts... any quick tips for upgrading a rc10 for maximum runtime...? like change to a lower usage engine maybe...? a bigger tank...? a combo of both...? im not really good with the intricates of this car, since i just bought it and i am just starting in the hobby (first car)...
#1581
Bring more fuel...
The less powerful thh engine the more likely it is to use less fuel, since it's not drawing as much in on each stroke. On the other hand, a more powerful engine may use more fuel, but will be more efficient at moving the vehicle just as fast as the less powerful engine, but requiring less effot, using less fuel. In short, both engine are just as likely to use the same amount of fuel in a given run. It's just once may last longer, while the other may travel faster. You could mount another tank on there somewhere too(not sure where or how) but that would just mean added weight, which isn't good for racing, and will just make you use more fuel in the long run. I'd say your best bet is to tune what ever engine your using so that you get the leanest mixture possible, without runnign the risk of severely damaging the engine. That's really the only way your likely to see any significant improvement in total run time per tank, unless you just keep topping off the tank while it's running. In which case, see my first statement.
#1582
no but my friend has ( he runs almost the biggest nitro offroad site in the world www.nitrobuggies.com ) seen it. standing them up will make it bouncy in my experience.
Dann
Dann
#1583
Hey guys I bought an RC10GT about two weeks ago. So far so good. Aside from the fact that I know I don't have it tuned right. I don't own a VCR so the tape you get with the kit is no help. Is there any videos on the intenet I could watch? I have search and found nothing.
Liz
Liz
#1586
TX
ORIGINAL: TsuaSai
Went I search everything that comes up is about that stupid video. I will try to reword my search some.
While I'm in this thread, I'll add something. I just ran 3/4 tank through my truck real fast and mannnn it ripppss!!! I just installed some new front aluminum bulkheads from Team Bluestar for extra strength. I was just running it up and down the streets around me, chasing cars (catching up so easily), and doin speed runs... I love this truck so much!!!
#1588
TX
I have two really sturdy zipties holding the coupler on. I cranked down REALLY hard on both of them with 2 pairs of pliers when I put the zipties on. I've had them come off a couple times, but not recently. Just get two pairs of pliers or something (one to hold the big part of the ziptie, and one to hold the end and pull) and just crank down on them as hard as you can to get it really really tight. Just make sure you don't pull it sideways and pinch the coupler right off the muffler or manifold
Oh and I've tried hose clamps on the muffler before, and they don't work well at all.
#1589
MD
TSUA
What engine is it, try searching for that engine. If it is OS they tend to have pretty good tuning guides. I am sure someone here will know the factory settings to start with, and adjust from there.
Took me a little bit to get mine tuned, but it is holding the tune really well, and hauls major a@@.
Shame I need to sell it
Tiny
Tiny
#1590
I belive it is an OS. One problem that I am having thats easy to explain is when I break it dies.
I will keep search for some standerd settings so to speak.
EDIT: I just search for OS engine manuals and finally brought up a lot of help full stuff. Thanks
#1591
OH
tsua your problem is the idle speed screw. you need to take your air filter off, and turn the idle screw in until you have about a 2mm gap (rotary carb) or 1.5mm gap (slide carb) when you're on the brakes.
#1592
ORIGINAL: ThunderbirdJunkie
#1596
Well its a stock RTR if that helps any...
Either way I am about sick of dealing with it. Might just stick it on ebay if i cant get it running right.
#1597
so its a TTR engine. turn the throttle trim on the radio so it put s the brakes on when u let go of the trigger. then turn the dile screw in until it will idle nicely and its fixed.
Dann
Dann
#1599
MD
TSUA
Thats a start. You just have to play with it some, I know its frustrating, but its all worth it when you get it adjusted and you get to wind it out for the first time. . .and actually stop too lol
I just got a new motor for my other truck so i have to go through all the adjusting and breaking in again. . . not the fun part of the hobby but something you just have to expect. Hang in there you sould pretty close to getting it tuned.
#1600
hi there, at first sorry for my english, i am from austria.
next week i will get a rc10 gt factory team and i want to know what a type of engine i had to buy?
i do not wanna race with the car, just go for jumps and i like to go for speed. what do you think about this motor?
LRPZ.12R TEAM SPEC.2
horsepowers: 1.58
3 000 - 42 000 U/min
is this good enough or is this engine to samll.
is a big block better or is this ok?
thanks for answeres
mihael
horsepowers: 1.58
thanks for answeres
mihael
