Nitro Rush Won't Move
#51
TX
RE: Nitro Rush Won't Move
I have the T3.0 in my Rush and the clutch bell turns the spur gear. I checked the slipper and it seemed fine. Maybe I just need to tighten it a whole lot.
#52
OH
fire it up with the body off, hold the truck in place, and watch the nut/spring on the topshaft. if they spin, with the truck stationary, it's something inside the transmission (likely the diff)
Do you have any aftermarket drivetrain parts? MIP CVD's, anything like that?
#54
TX
I ran it today and it ran great... for about ten minutes. Then it stopped accelerated when it got to about 10 miles per hour. It would accelerate until then and the engine would rev up but it just wouldn't go any faster. I would tighten the slipper but it was tightened as far as it would go. I really don't know what is wrong as all the gears seemed fine when I looked at them.
#56
TX
The engine runs fine and turns everything. I'll take a closer look tomorrow and see if the brake moves since it is behind the slipper clutch. If it moves, it isn't a slipper clutch problem.
#58
TX
Yeah, but I allready did and it ran fine for about ten minutes and then had the same problem of not accelerating past a slow speed.
#62
TX
On another note I need stiffer springs for my Rush. I have MT2 shocks in the rear and they fit really good. I was thinking of getting the purple springs: [link]http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXGJU2&P=Z[/link] or the blue springs: [link]http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXGJU1&P=Z[/link]. I think these would help keep the rear from scraping!
#63
TX
I ran it today and heard a grinding noise coming from inside the tranny. I think it is the diff. ThunderbirdJunkie, were these the MT2 gears that fit the Rush: [link]http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXBTA4&P=Z[/link]?
#65
TX
ORIGINAL: Montana Mike
WHats goin on 66? I believe that is the gears you want. I hope so, cause I have a few new sets of those for my Rush trucks. So now you get to rip the whole things apart again. Bummer Deal !Besides the grind, how did she run?
#66
I have heard nothing but bad things about the primer tanks, nice concept, but bad flaws. Here is a link to a good fuel tank.
[link=http://www3.towerhobbies.com/cgi-bin/wti0095p?FVPROFIL=++&FVSEARCH=72525&search=Go]Fuel Tank for Rush[/link]
To bad you did not see the the spider gears when you initially opened her up. Best of luck and hope to hear you get her running good soon, keep us posted
#67
TX
#69
TX
I replaced the differential gears in my Rush today with new MT2 gears and found a nice suprise! Since the MT2 has 2 diffs (I think) I have an extra set of gears! Anyway, when I opened up the diff I saw that the grease was shiny and had small pieces of metal in it. The stock gears were very worn (how did I not notice this before?) so I put the new ones in. It now runs likes its brand new! It stalled a few times but I just adjusted the idle speed and now it runs great! I'll post some pictures of the old gears next to the new ones tomorrow! [8D]
#71
hey all im very new to the site cousin gave me a nitro rush evo, I cant get the truck started for the life of me, fresh gas fresh plugs tuned it just like the book said and cant get her started.
any help you guys have would help greatly or else i have to take it in. thanks
#73
TX
I ran my Rush today and after running it I took the glow plug out, put some after run oil in it, and tried to screw the glowplug back in. However, instead of screwing in easily like it normally does, it tried to screw in at an angle and was hard to turn. So I then had to force it to screw in straight up. Do you guys think that the threads could be stripped in the engine?
#75
TX
Well it doesn't sound good, thats for sure
