XXX-NT upgrades
CA
RE: XXX-NT upgrades
MIP clutch, Dynamite makes some aluminum parts, RR alumium diff gear. There are a couple. Search XXX-NT on ebay and you will find some more. IMO the NT is great out of the box, really nothing eeds to be changed.
CA
RE: XXX-NT upgrades
ORIGINAL: MPevine11
would the adam drake pipe improve it any? i like how that pipe mounts and wondering if it would make perforamnce change.
CA
RE: XXX-NT upgrades
ORIGINAL: MPevine11
what does the MIP clutch do for performnce?
PA
RE: XXX-NT upgrades
do we need an explanation of what a clutch does everyone? its gonna give u a better power transfer from idle to wot, faster accel, and it will last longer
the xxxnt is not the basher type its made for racing and most upgrades are racing developed
RE: XXX-NT upgrades
i want to race it.....i will not not bash it
im looking for parts to increase accerlartion.....
increase top speed would be alright also
RE: XXX-NT upgrades
all you need then is a good clutch and the right gear setting
its not about upgrades its about setup and skills
maybe another thing could be the servos, you def. need some fast ones
and there is alot to setup
the (mip) clutch itself
gearings
shocks + their position
tires + foam
camber
and the right pipe for your engine
gearings
tires + foam
camber
RE: XXX-NT upgrades
ORIGINAL: RCUSEE
gearings
tires + foam
camber
gearings
tires + foam
camber
i have the manch .15 what would be a god pipe?
what is camber?
what would good gearing be?
CA
RE: XXX-NT upgrades
The best thing for you to do is go to the track where you will be racing and run your truck a few times and get to know the people at the track. They will be much more help to you than anyone around here could be because they know how there track is faster is not always better in ST racing and unless you have had the practise to stay in front of everyone on the track don't worry about how fast you are just worry about getting around the track. A good racer can win with a lot less power than needed to win a fast straight away contest [:-]
RE: XXX-NT upgrades
there is no "the" setup
it varries by circumstances
but for a regular race i guess you should buy a .12
camber is the angle of the wheels if i havent translated that wrong
