HPI Firestorm running really hot
My Feedback: (14)
VA
Hey Guys,
Ihave a HPIFirestorm that Igot in a trade that Ican not seem to get to run cool. Ihave cleaned out the engine, Ihave a new glow plug and I am running 20% O'Donnell Nitro Fuel. Ihave the needs HSNand LSN are both set at the stock positions. WIth that, I ran my Firestorm today and Isaw temperatures in the 260 ~ 290 degrees. Do Ineed to run a lower Nitro content fuel??? Ireally need some advice. Ihave even thought about getting a bigger heat sink for this firestorm.
I really need help to get this running cooler. PLEASEHELPME!!!!
Disjaukifa
Disjaukifa
My Feedback: (14)
VA
RE: HPI Firestorm running really hot
ORIGINAL: JCMINIS
Jow does it run ? Why not richen it up a bit ?
Disjaukifa
WA
Slow down the idle maybe your idle is really high so your RPM starts of high and when you full throttle it, the engine reachs its danger zone. Or you might have an air leak
QC, CANADA
I had the same problem with my firestorm 10T last summer . It was too rich to have good performance but did not seem rich enough to keep it cool below 250 F . I did not solve the problem but i bought racing tire for stadium truck and i raced my firestorm in a parking and it did not overheated at all ! I guess it is because of the ventillation it was getting due too the speed it was going. My point is : Maybe when we are bashing around with it it revs too much for the speed it goes. It is a little bit like when you drift an on road nitro carmy RS4 evo 3 with racing setup can take lot of beating and will still be under 240 F but last time î had put drift tire on it after few minutes i was running 290 F and the bodies are full of aeration holes !
in grass the firestorm over revs a lot because the tires do not always get fully to the ground. also when one tire gets traction and the other doesnt the diff will unload like crazy. i solved this with 100k diff oil and it runs much better in grass but it still is no were as fast as it is on dirt.
QC, CANADA
ORIGINAL: CrysisFX
Yes that is true the stock diff setup is very loose and always give all power to the "no load" wheeland make the engine rev very high !!!
My Feedback: (14)
VA
ORIGINAL: jenfre
Yes that is true the stock diff setup is very loose and always give all power to the "no load" wheel and make the engine rev very high !!!
ORIGINAL: CrysisFX
Thanks guys I will keep you updated on how it goes.
Thanks again
Disjaukifa
IL
my son has a firestorm and we cannot get the temps below 270 or it just wont run right and its been that way since it was new .... some motors like hpi and traxxas tend to run a bit hot .... dunno why, i guess its just their nature ,,,,,also if the low end mix is a bit lean ya will run hot too, motor can be blubbering on top end and still run 300+ .... fatten up the low end and hello there's 230 and she screams ... make tiny adjustments and work ur way to a decent tune
My Feedback: (14)
VA
ORIGINAL: MCSRacing
Disjaukifa
CA
Most RTR engines like to run hot. If it is under 300 degrees then you are ok. I like to keep my engines under 280 as they can be pushing 300 when you are running WOT. Also, get race fuel. Please tell me you are using ODonnell race and NOT R2R? That will cause it to run hot. If worse comes to worse, buy fuel with a lower oil content (race fuel) and higher nitro percentage ($30). Nitro burns cool, oil burns hot. Also check for an air leak. How much runtime is on this engine?
My Feedback: (14)
VA
ORIGINAL: Chris_RC
Disjaukifa
CA
ORIGINAL: disjaukifa
Its a brand new G3.0 and Iam running R2R, however I just bought Tower Hobbies 30% Nitro so hopefully that will lower the temperatures a bit.
Disjaukifa
ORIGINAL: Chris_RC
Disjaukifa
My Feedback: (14)
VA
ORIGINAL: Chris_RC
Yea DONOT EVER run ANY RTR fuel. It is very cheaply made and bad for motors. The extra oil gives bashers a fake sense of extra lubrication. I wouldnt of bought the Tower fuel as you dont know how much the castor to synthetic ratio is. Stick with brands like Byron (my personal favorite), nitrotane, Sidewinder, O'Donnell, and Maxy's.
Disjaukifa
ORIGINAL: Chris_RC
Disjaukifa
UPDATE The tower hobbies fuel runs a 14% oil content, which seems to be pretty low or should Istill get the racing fuel from O'Donnells???
Disjaukifa
IL
some times it takes a bit of fuel to get a motor to settle down on the temps .... as far as fuel goes ... O'Donnell is killer fuel .. i personally run trinity fuels, they tune great and seem to have great wear so far ... i ran blue thunder for years in my play trucks but i've switched to trinity eclusively, but then we have a real hard time getting byron gen2 lol 30% is too high of a nitro content for a basher .... 20% will give ya good performance, we only run 30% in our race motors, with 30% ya can run ur motor fat and still have good performance and cooler motor temps, but everyone i know can't leave a motor fat so they lean it out and then the benefit of the higher nitro content cooling the motor is gone. so its a trade off!! oh also to get a ball park tune on the low end needle pinch the fuel line a round 2 inch's from the carb and it should take about 3 seconds for the motor to die.
CA
14% oil is still pretty high IMO. I mean Losi Nitrotane Sport fuel is only 12% oil. All your engines really needs is 8-12%, any more only hurts it. ODonnell is good fuel, but it hurts my eyes alot. Trinity is good fuel, I ran a quart of PLatinum 20% when I forgot my Nitrotane,but nothing like Byron.
My Feedback: (14)
VA
ORIGINAL: Chris_RC
Thanks guys,
Disjaukifa
CA
Wow, 18%!! That is very close to Traxxas fuel oil %!! Going down to 14% should make a big difference. Every engiene ive owned wont even run at factory settings.
My Feedback: (14)
VA
ORIGINAL: Chris_RC
Disjaukifa
The problem is that HPI engines are just cheap and crappy sling it out and buy a proper motor like a nosram i had nothing but trouble with my G3.0 it ran at temps like 130-160 degrees c and couldn't get it any lower so just use it at that temp only thing is yul go through quite some glow plugs due to the heat.
