Transmission trouble on my Losi XXX-NT AD2...
The idler gear from the P/N set A2927 keeps stripping. My original gear last about 2 full seasons. Then it stripped. So I replaced it. The next time I ran it the new gear stripped before I finished a full tank of fuel. Maybe 3/4 tank. So I thought maybe it was defective. So I put in another one. This time I got about 5 tanks of fuel through it before it stripped. I didn't even make it to the first heat race. It stripped during morning practice. Because this is rediculous having this gear constantly stripping out. The stock input gear (P/N A9931 is alum. I replaced the differential gear (P/N A2925) with the Robinson Racing alum gear when I first built it. Only the idler is Nylon and it keeps stripping now. So does anyone make an aftermarket idler gear out of metal?
NY
RE: Transmission trouble on my Losi XXX-NT AD2...
Check the case where the bearings go for the compound gear, I’ve broken several there and the end result is the compound gear destroying and taking the monster gear with it. Also make sure there are no plastic remains left in the top gear, some times they get jammed in.
IL
ORIGINAL: All The Way
I guess I should have added, its a new transmission case too so it's not cracked. I replaced the case the first time I rebuild it.
NY
hmm, bearings to?
I'm hard on my trucks when I race. If I find a spot I can land on power 9 times out of 10 I will, I'm never light on the trigger and I may have 2 in a year fail.
Not sure on this one, metal gears is definitely not a solution to a possibly bigger problem.
IL
i just replaced the cases in my drake, broke them at the output bearing carriers lol ...... i run the rrp aluminum diff gear and the delrin compund gear, ya must have a weak link to fail if something goes wrong .... the aluminum compound gears dont seem to last and better and they definately destroy ur trans when they go out
ORIGINAL: MCSRacing
