Steering on a nitro Rustler
Hey guys, little help would be much appreciated! Just picked up a nitro rustler - 1st rc nitro car and notice the steering kinda sucks for lack of a better word. Now this is the only one i've ever drove so i really have nothing to compare to. But I was wondering if there was a way to get a wider range of steering to make tighter turns also if they sold some sort of steering damper the stiffened it up on strait aways. As soon as I punch the throttle the front end gets all squirely even with the alignment dead on... I'm thinkin even weighing down the front end so it'll dig more might help but with speed weight is usually the enemy.
Also on a another note the brake's are pretty week too. I've played around with adjustments and it just doesnt stop as fast as I think it should and isn't even close to lockin up which would be nice in some instances....
Again thanks for any help!
RE: Steering on a nitro Rustler
Any suggestions on a prticular branD?
ORIGINAL: Chris_RC
Get a better steering servo. A $40 servo will end your problems.
ORIGINAL: worstluck
if you put your battery up front youll get more bite & weigh the same. your rear end will feel a little looser though.
CA
ORIGINAL: rustler1882
ORIGINAL: Chris_RC
http://www.amainhobbies.com/product_...S%252FJR%252FZ
Then you would mvoe your stock steering servo to throttle. It is pretty easy actually. You will notice the wheels will turn a lot easier with this servo, and if it ever dies Hitec will give you a new one.
Great thanks alot - not a bad price either. Thanks
ORIGINAL: Chris_RC
This would be your best bet.
ORIGINAL: Chris_RC
hey guys saw this form i got a question too. on my rusty it seems like there is alot of slop in the front and rear is there a way to tighten this up?
ORIGINAL: Nitrohobo
hey guys will http://www3.towerhobbies.com/cgi-bin...?&I=LXTKH5&P=7 work for the nitro rustler? i was at the dirt oval and flew and destroyed my stock bellcranks if these dont work what other ones would you recomend
IL
ORIGINAL: Nitrohobo
hey guys will http://www3.towerhobbies.com/cgi-bin...?&I=LXTKH5&P=7work for the nitro rustler? i was at the dirt oval and flew and destroyed my stock bellcranks if these dont work what other ones would you recomend
