holding down stinger pushes fuel out of the engine
when i use a roto start to start my nitro rustler i prime it and when i plug the stinger with my finger and hit it with the roto start the gas moves down the pipe away from the carb and goes back into the gas tank... i flipped the one way bearing around and still the same effect....im using an ofna roto start on the motor and a team losi handheld starter...any help is appreciated
CA
RE: holding down stinger pushes fuel out of the engine
Take out the exhaust nipple fuel line and blow on it. Fuel should come. I personally just push the roto start button for a couple seconds then start it. Is the piston moving up and down?
yeah i blow on it thats how i prime it...the piston is moving up and down... when i push the rotostart it goes out of the carb fuel line and back into the fuel tank
CA
Look for leaks in the tank, fuel line, etc. What I would do is heat up the engine and put fuel in the carb and quicky put the air filter back on and start it up immediatly after you put the air filter on So fuel is still in the carb and see if it starts. Once you get it runing you should be fine.
