Cleaning after Sitting for sometime
Hey Guys I purchased a Nitro truck a while ago and just got busy and had to put it on the back burner for sometime. I am now in the process of gettng it to running condition. Ijust have a few quick questions. #1 not so smart of me I left fuel in the gas tank and now it has turned into more of a thick liquid. Ihave read other posts on how to clean the gas tank and have cleaned it out with soap and water but still have some residue of gas and having difficuties getting rid of it. What is a good product to clean out the tank? I have heard of using fuel itself but I not sure if it will get rid of the gunk in the tank. Also Iam wanting to clean the Carburetor to make sure there is no dirt or anything in there. Can you use regular Carb cleaner or can you use WD 40? I am fairly new at this and dont want to screw it up before I get it back together. I would apprceiate any suggestions and look forward to your responses. Thanks
Mark
Mark
PA
RE: Cleaning after Sitting for sometime
the gunk in the tank will be cleaned with some new nitro fuel
the carb cleaner will clean the carb
the only problem i see is letting the car sit with fuel in it collecting water which couldve squezed into the engine itself as soon as you can after you clean the carb dumb (well dont exactly dump a few drops is all) some after run oil through the carb and in the glow plug hole
and if you are open to it in order to clean off dust and debris use compressed air
it works well
it works well
