RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
big problem with nitro motor!!!!!!
Old 03-15-2010 | 05:49 PM
Default big problem with nitro motor!!!!!!
i have a rustler 2.5. well today i began my run by increasing the idle a little bit. toward the end of my tank i notice that my my low end throttle seemed to be cutting out when ever i accelerated. i was able to go high speed fine but it is the low end i had trouble with. so i brought it in and richend the lsn. i also adjusted the idle to tone it down a bit. well i then tried to start it and it wouldnt. i didnt make any drastic changes to prompt it to not start.
so i tried increasing and decreasing idle, richening lsn and leaning it but no matter what i did it wouldnt stay going. here is the weird part. i can get it going if i keep the throttle half way which in turn engages the clutch but will shut off as soon as i release. but even when i lowered the idle and tried to start it, it would atoumatically engage the clutch no matter what the idle is at. i sat for over an hour trying everything. i also saw the spur gear and the clutch bell region starting to smoke. it now also sqeaks somewhere when i rotate the flywheel. what the hell is wrong?
Old 03-15-2010 | 06:31 PM
Default RE: big problem with nitro motor!!!!!!
have you tried to put everything back to factory settings and did you check the settings on the remote.
Old 03-15-2010 | 10:48 PM
LOL yeah i have done everything. i am putting it back to stock now but it seemed like the clutch bell was sticking. i just got finished taking it apart and oil and cleaning it. oh also what would be some good upgrades to get for performance with this thing? i got a 40 dollar amazon card....
