RE: Official RC10GT Thread
Check out the site i just made.. I have an rc10gt+ with an o.s. .18 on it :D http://freewebs.com/kovertrc
Nothing on it...just your banner.
hi alll i was wonderin how bad of an idea is it to temprorarely hard mount my front suspension? could this cause a major change in handleing? thanks
ORIGINAL: brennan l hi alll i was wonderin how bad of an idea is it to temprorarely hard mount my front suspension? could this cause a major change in handleing? thanks |
ORIGINAL: J_Bone Which OS do you have and how is the Picco? I want a faster motor with better fuel mileage and I have come credit at Nitro House and that Picco is priced good too if it's faster than my OS .12 cv-r?? |
i need a racing motor, im getting upgrades and im going to race it[>:] dirt racer said to go with the picco but said its discontinued, what to get:eek:
ORIGINAL: hanney i need a racing motor, im getting upgrades and im going to race it[>:] dirt racer said to go with the picco but said its discontinued, what to get:eek: |
novarossi or picco they still make piccos just not the one i have i got the last one, i think, its still new like only a gallon threw it and still getting faster:D
yeah im serious im tooo cheap to buy new and i blew out my font shocks tryin to jup it off my house.dant ask why but i got a rossi engine out of it so i though that wasnt a bad price to pay. thanks brennan
What blew out? o-rings or did you actually bend something? The shocks are rebuildable for cheap.
well this is kinda bad but i ran it into a culvert and blew off the whole front end a ripping the engine in half so the shocks are bent. also does anyone have an engine they are willing to get rid of kinda cheap becuse someone gave me some kind of motor called an SMT and it wont work on an rc-10 thanks brennan
check ebay or even www.nitrohouse.com for a motor, a reabuild kit is like 10bucks and shafts are like 3 bucks
um i ripped the whole engine block in half. will a hpi .15 fit in an r10 because the motor i trade a 4-tch for doesnt fit
can i get a link to the novarossi or the picco?
or ill get a os .18 cv rx, what type of shaft should i get? edit- and ive seen this motor on alot of rc10's [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXBZ15&P=ML]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXBZ15&P=ML[/link] |
ORIGINAL: hanney what type of shaft should i get? |
threaded and then you have to cut it and buy a 5 dollor part from accosiated
kool but cut it cant u just buy A short saft motor
mayby all my motors i cut cause its not a problem and all the better motors need to be cut
oh ok i have a 2 gear clutch bell on that smt motor and it will not even pretend to fit
Has anyone with a .18 os cvr found out what the top speed is? I have only got 44 so far, with minimal tuning and little road tires.
ORIGINAL: blazed4twomp Has anyone with a .18 os cvr found out what the top speed is? I have only got 44 so far, with minimal tuning and little road tires. I might try to get mine clocked or even buy a radar gun, but I doubt it'll be much (if any) more than around the 40's. I prefer acceleration over top speed though any day for the bashing that I do!! [8D] Oh also - I run mine pretty rich anyways - Runs a lot cooler, and the motor will last longer! And man I get totaly insane fuel mileage with my motor and kickbutt fuel tank. |
gear mesh has absolutely nothing to do with top speed. maybe i misunderstood you pilot wings but thats what i got from your last post.
the .18 doesnt rev all that high so you wont really see a speed increase without changing your gearing. it makes a ton of torque though so you can gear it way up and see a top speed gain. |
how does a o.s. cv .12 do on an rc 10? i have heard good things abought these engines and they aare cheap thanks
I've got a new RC10GT that I bought from my friend, and I'm having a problem with it. He's coming over today after school to look at it, but I thought I'd just ask you guys first.
So basically, I'll start up to motor and hold the truck down with the tires pressed against the ground pretty hard. When I rev the motor, the spur gear spins around, but the wheels don't. It's not a gear mesh problem, and it's not a axle pin, wheel, or hex problem. The guy I bought it from thought it was just something that needed to be tightened or adjusted. I thought I tried tightening that slipper/spur screw and put it really tight, but I may be wrong. I also don't have a socket that will fit other than the plastic one the RTR kit comes with (he included all of that), so it makes it hard to get as tight as a metal socket would. I have another question too - late last night when I was removing the screws to get the tranny off, I broke the only allen wrench I have that fits those screws. It must be a very odd size... I have a set of about 10 Standard allen wrenches, and a set of 8 Metric wrenches. None of them fit right. Where can I buy a tool set or something that will fit these odd-sized allen screws and nuts? Thanks guys |
