Who can recommend a good airbrush?
CA
I'd like to start painting my own bodies and I'm wondering what would be the best type of equipment to get. I already have a compressor so all I would need is the airbrush.
RE: Who can recommend a good airbrush?
I have a Badger 200. It is not too bad but not too good. It cost around $50.
How much are you willing to spend? That will put you in a ballpark to choose.
I didn't want to spend much because it is my first airbrush. Now that I've used it for while now I'm thinking of going up to about $100 and see what I can get.
The Badger 200 doesn't do very small lines with the water based paints but does a nice job with lacquers.
Here's a few pics of the bodies I did with it.
OtterBall: can you explain what you mean a little more with the water based paints. i myself am getting onto airbrushing, and i have this problem with the paints i am useing. they are "exploding" when i try to do a fine line. i am using FasKolor water based paints.
thanks!
thanks!
Badger 360.. about 140 bucks with mixing cans.... No more changing needles... you can pick up a good compressor from Lowes for about 80 bucks w/ regulator... under 250 for a great setup! and the compressor has enough umph to blow off the cars on a race day.... check it out...
ON, CANADA
I have an IWATA too they are great airbrushes
I can do a hairline with water based paints and the brush I use can also handle thicker and heavier paints
Its called the IWATA Eclipse BCS Its a bottem feed airbrush
Its my first but its great and will not need to be replaced when your skill improves lots people on line use this brush
Nick
Nick
CA
I bought a Paasche VL and noticed that it comes with different needles.
Can someone tell me what these needles do different from each other?
I Just bought the same airbrush. i love it.
the 3 needles are for differant size sprays...
example:
the needles that is in it is a number 2 needle, and tip. that is for medium lines, and coverage.
there is a needle number one in the box, this is for ULTRA fine lines, and small area coverage.
the other needle is a number 5, this is for heavy lines, and large area coverage.
by needle i mean the needle and the tip that is also provided. you need to change the tips when you change the needles.
example:
also i noticed in another post you asked the difference between the VL and the VLS... the VLS has a screw in paint jar, unlike the VL that just pushes in.
Personally i like the push in better then the screw in, but its just personal preference.
CA
Thanks for the info Speeddemon. I mainly want to use the airbrush for those extra fine pinstripe jobs ans I also like the airbrushed headlight look.
