Help me identify this switch/reg
Old 04-19-2011 | 12:35 PM
Default Help me identify this switch/reg
I'm replacing this switch/reg with a dual redundant system but would still like to know what this one is. I may use it in another sport plane but I know nothing about it. Was in used Temptation I bought
Any help would be great
Old 04-19-2011 | 02:54 PM
Default RE: Help me identify this switch/reg
It is a Mpi Miracle Switch. p/n ACC407. I just purchased one at a hobby shop.
It is a 'fail safe' design with a built in 6V regulator that can draw up to 0.05ma when turned off. Mpi recommends that you disconnect the battery if you plan to let your model sit for more than 30 days.
The current version has a fancier case. [link=http://www.maxxprod.com/mpi/mpi-21.html#Miracle%20Switch]Miracle Switch[/link]
Stan
Old 04-19-2011 | 03:19 PM
Stan
You are da man....I even found a PDF now for it.
Thank you so much
[link=http://www.maxxprod.com/pdf/ACC407-409.pdf]Instruction Sheet[/link]
