JR 8411 to 8411SA gearset
Anyone know the part numbers for just the nylon gears that are required to turn a JR 8411 into a JR 8411SA? I don't want to buy the whole "Hybrid" gear set which JR sells if I only need three nylon gears. I think the metal output gear is the same between the two and the only change is to make the remaining three gears from nylon.
My Feedback: (8)
You can use the gears from the 8101,8231 set and keep the output gear you already have.
http://www.f3aunlimited.com/webstore...roducts_id=365
