Pattern Rules Proposals
#177
NC
ORIGINAL: petec
Have you looked at Ed Alt's stuff? It's light, well designed and less expensive than the power box, but does not give you the indication the power box does which you say you do not want to give up. Cheaper, lighter and pretty bullet proof might be worth a gander.
ORIGINAL: rix
Appreciated...I like the Powerbox switch as its two regulators are built into the single case and it has nice safety features built in which illuminate leds on either side when it detects any issue in the system whether it be a low cell in one of the packs, one of the regulators going bad and or electrical failure on either side, so I am not willing to give those features up. My packs are connected in series using 4m bullets. I use bullets on everything. My castle 80 has been sent back for the recall, but I will check when I get it back and re-address how I am configuring it. Any of the Falcon props look nice and i am sure they are but even at $72 It would be prudent to have two as I know they are prone to tip chipping and would render a $72 display on my work bench. Then one would need to spend an additional $72 to get the backup in place again. My $15 APC performs beautifully and I simply cannot justify the Falcon cost as the performance that I need, the APC delivers. The only time I ever used CF props were with the YS140's as they did produce a little more efficiency in that setting and I justified the cost because of it. When it comes to performance I will always justify a cost. I would not consider using 4400's as it is not enough for me personally. It might be for others, but I put 3700, sometimes more back in on windy days and I am not going to sacrifice my plane or my batteries to save a few ounces. 4900 or 5000 is what I use and would not feel comfortable using anything less. The GP spinners and lightened back plate comes with the Vanquish hardware package.
#178
NC
ORIGINAL: petec
ORIGINAL: rix
#179
NC
ORIGINAL: nonstoprc
rtx,
One of the two 350mAh batteries could be replaced by a smaller pack as you probably only need 50mah per flight.
Thunder Power's 125mah 1s (part# TP125-1SPL25UM) weighs only 3.4 grams (at $7 per piece). Two of these will be 6.8g. If your current 350mah is TP, it is 22 grams. A saving of 15 grams after replacement and you still have 250 + 150 = 400 mah of capacity. I am currently flying with a single 250mah TP at 17 grams for every 4 flights. Two of 250mah will give me 8 flights.
Also, I am using the same GP plastic spinner with the lighter alum backplate as you are. It weighs 4oz and I am thinking drilling some lighting holes on the backplate. Mejzlik also makes very nice-looking and super light carbon fiber spinners for E pattern. DA might carry them.
Lastly, if you are using steel bolts to secure the motor, consider replace them with titanium ones to save half of the weight.
ORIGINAL: rix
I went through all of this on another thread somewhere I think, but, I am flying a Vanquish (which I really like...allot) using all stock stuff and less expensive zippy 5000mAh 25c batteries, a redundant Rx power system with two 350mAh batteries, dual regulator (Power box 12), an APC 20.5x14 prop an arming switch, and a Himax 210 motor, I came out at 5100. That’s cutting it close for attending the nats in Advanced so I went out and spent more money on lighter packs which brought me down to 4998. Comfortable for Advanced this year but next year when I move to Masters I am too close for comfort again and will be forced into an elaborate set of choices and or expense, for example:
1) Make my equipment less safe by pulling out the arming switch, removing the redundancy system and or replace it with the a slightly lighter system such as using the flight packs for redundancy and or remove an Rx switch altogether and only use a regulator, or purchase expensive HV servos so I will not even need a regulator.
2) Pull out my wires from the elevator servos and let the two share a common pos and neg pair of wires too lose weight and remove my redundancy their in the event one of those pos and neg wires chafe and or the one cable pulls from the receiver leaving me with no Elevator control at all. I guess I could also take the dremel to my really nice airframe and start gutting it in strategic places.
3) Drop my sexy wheel pants.
4) Replace my $15 prop with a $90 one
5) Replace my $4 spinner with a $130 one
6) Replace my really nice CF landing gear that came with the kit with a set of $40 to $80 lighter ones.
7) Replace my $279 Himax motor with a $500 to $800 lighter one
8) Replace my really nice Futaba digital and BLS servos with HV ones so I can remove the regulator altogether.
9) Continue to purchase more expensive flight packs.
Anyway, these are my experiences and choices, currently.
ORIGINAL: nonstoprc
rtx,
Do you mind post some info on your plane? Is it way over-weight?
rtx,
rtx,
#181
NY
Where are you getting the titanium bolts?
They have almost anything you could imagine, and they ship so fast you'll think they mailed it before you ordered it.
Of course, they're not cheap!!
#182
ORIGINAL: cmoulder
[link=http://www.mcmaster.com/#socket-head-cap-screws/=g13o63]McMaster-Carr[/link]
For electric stuff, why not use aluminum bolts? In my search for strong and light, I've saw some Ally aircraft alloy bolts with rather high tensile strength (probably more than adequate for e-stuff). Ally is around 2/3rds the weight of Ti at 1/3 the cost (I think that's right). Met Tec is one decent source for Ally bolts too. My search was not exhaustive by any stretch and I had no interest in Ally alloys so I didn't dig very deep. I could be a little off in my estimates.
For a really snazzy look, take a look at their anodized colors, but these are even more pricy
#183
My Feedback: (25)
ORIGINAL: petec
Can you qualify that statement? I could certainly say the same about the weight rule. I have no issues with any of the rules as they stand and built my plane to stay within the rules. I heard the arguments about glow vs electric weighing, the fuel tank for an electric weighs more than the fuel tank for a glow plane while conversely the fuel weighs less, and those arguments don't pop up now that battery technology has gotten better and airframe construction techniques lighter.
As I have said before, the rules form the boundary that we compete within. If you remove a limitation without imposing an equal limit you will see escalation due to the fact the this is competition and we, as competitors, want to gain any edge we can. You may certainly disagree, and I expect some do, but it would seem that the leeway given the lower classes for weight did not reach to Masters for a reason. By the time you compete at the National level in Masters you have decided to commit time and resources to this hobby that those in the developmental classes may or may not. Now whether that is the sole reason or not is not a concern of mine but it is a valid statement nonetheless.
ORIGINAL: rix
Petic...The size rule is in place for obvious and rational reasons.
#184
ORIGINAL: Ryan Smith
Still waiting on a response on this. Why do we have the 2-meter rule, and why is it more important than the 11 pound weight rule?
There was a time (70's? maybe even a bit later) when size was not a limiting rule
#185
ORIGINAL: MTK
The AMA followed the FAI paradigm about 20 years ago.
We have just been through a provincial (state) competition locally where the pattern rules have come under fire. I am not against rule modifications perse but 2m / 11lb is what we currently consider pattern. Locally many LSA pilots consider pattern "expensive" but that is just because of the lack of international participation in our LSA. Size is cost and if you want a bigger plane then fly F3M. IMAC doesn't count (locally in any event) in my opinion as I fail to see the PRECISION in IMAC.
I would rather consider weight increases. The current 11lb weight limit is a legacy of the "glow"past. A 12lb ( or 13lb) weight limit would open the field to many more cost conscious 'electric' pattern pilots. Maybe allow a 2lb leeway for electric only? The weight penalty combined with the size limit will be enough to discourage top pattern pilots from following suite, especially at the 2013 world champs at 4000+ feet ASL and 90F and above.
#186
My Feedback: (10)
TN
ORIGINAL: petec
ORIGINAL: rix
Because doorways in Europe are 2M high. If you build airplanes any larger, they can't get them out of their apartments. . . .
#188
ORIGINAL: klhoard
BTW - I just made that up . . .[img][/img] [img][/img]
#189
My Feedback: (10)
TN
ORIGINAL: grantb
And there I was just thinking that EVERYTHING in the USA was bigger
ORIGINAL: klhoard
You oughtta see the 4 meter pattern planes they fly in TEXAS!!!!
I think this one is McHarg's . . . .
#190
We all know that the 5000g rule was set way before the advent of e-power for our pattern ships. Technology does continue to improve but we all know there was no thought of ever having an electric powered airplane when that rule was created. The glow ships easily make 5000g (typically and without great expenditures) and when that rule was made, 5000g would have been considered a ridiculously heavy ship.
It really is OK to change rules to adapt to newer technology. Technology has ushered in the advent of LiPo powered ships swinging 22" props and contra-rotating drive systems. We do want to innovate but sometimes in order to grow, our base rules need to be modified. I say we should consider looking at this simply due to the fact the rule is actually archaic and should be redefined based on current technology. Again, no way were electric powered planes considered for the current weight limitations.
#191
My Feedback: (58)
ORIGINAL: CLRD2LAND
#192
BC, CANADA
[/quote]
[/quote]
[/quote]
Keith......now THAT was funny!! Had a good belly laugh from that one!
Pattern planes up here in Canada have mittens on their wings and tail feathers and touques on their canopies!!
Re the weight rule change I would very much support at least changing the rules to even out the difference between EP and GP. Who's to say the GP guy has a half a tank left at the end of the sequence and after landing is still overweight? There is a common belief that a heavier airframe does not handle any better but I think in windy/gusty conditions the heavier loaded airframe has an advantage. Just my opinion though. I do know very well that gliders in those conditions really benefit from adding ballast.
Keep up the discussion......it is interesting!
Cheers
MJ
#193
ORIGINAL: petec
True and all those have flown at the NATS and made weight. Had the 5 KG weight limit not been there would the technology exist as it does today? Necessity is the mother of invention.
I don't believe in the "I did it so you can too" mentality. Not everyone has the money, skills or time that it takes to keep up with innovative resources that allow electric planes to be "easily" under 5000g. I don't think we should look at it within those terms. I think we need to consider everyone and especially those that don't participate for whatever the reason. Just because we made weight doesn't mean that Joe Blow has the money to do it as well. I think that if we go with this mindset, we will indeed wind up hurting the popularity and certainly the attendance of pattern competition be it on a local or national level. I think that we will be limiting ourselves and our facet then becomes a country club of the rich.
Almost every other country has adopted a 5500g weight rule for every class except FAI including Austaila, Europe and some of Asia. The UKhas even gone as far as a 7000g limit. I am not saying that we absolutely must follow the rest of the world but Iwould like to point out that the majority of the world has made this change for a reason. Are we just not willing to look at the potential good things this does and could provide because we are American and we do our own thing? I hope not.
#195
My Feedback: (58)
Everything costs money Scott, innovation and stagnation. What is the first rule of economics? There is no such thing as a free lunch.
I have such a small budget for my hobby that if escalation does happen, as I have seen in other hobbies over the years, pattern will nothing but memory for me. If for no other reason the is why I am so opposed to this unless we institute anther constraint. If the crux of the argument is truly to make things more affordable then we institute a price cap on the airframe/power plant combo and everyone is happy as well as having a little more pocket pocketchange. $2000 all up cost for a RX ready pattern ship as a cap and we are all happy, except the manufacturers.
This is very much a pay to play hobby, they all are. As I indicated above I do not have the monetary resources to buy a top of the line ARF and outfit with the best stuff out there, nor do I have the time to go and fly my face off to be the best I possibly can be. I can however build, use a scale and research my equipment to make sure I meet the rules. You may not be of the if I can do it you can too mindset, but if a person would rather relax the rules instead of work to meet them that falls under the the we are all winners mindset so why are we competing?
Unfortunately the airspace argument does not relate to this issue, the preservation and safety of human life and toy airplanes are nowhere near being on the same level in my view of the world.
Final point and then I will go back to lurking and just abide by the rules. If all these other countries have adopted a higher limit, what was the reasoning and the final impact on cost? I am curious what data has been gleaned from this that directly impacts this discussion.
#196
Hi Bob,
If there is, I don't have it sir. I'm basing this solely off of my opinion. I do see in that poll at least "X" number of people that say they would attend the NATS if.....
I try to use reasoning and I'm not saying it's perfect. I see a lot more people even in this thread that say they would like an increase more than are saying don't change it.
Sir, by no means am I being smart to you, I am just being honest.
Scott
Scott
#197
Pete,
The reasoning behind the example of airspace was weak I admit but, in a way, it does fall into play here. There is actually a safety reason behind this such as people changing the airframe to save weight, people running lighter gauge wire on the ESC, no arming switch on the plane and plugging a battery straight in to the ESC and it becoming live, people running 150mah-350mah rx battery packs to save the weight. All of these things, in one way or the other, are a safety concern. Of course, we've learned the hard way to not act until something happens but it will. Even the airlines have faced this same scenario. Don't worry about it until we get caught.
There are a lot of people posting in this thread Pete and you are one of those guys I truly respect. I don't have the data to back it all up but it is reasonable. I agree I should be able to present some of these things and I cannot. I'm simply trying to get people to think outside the box (pun not intended) and look at potentially the good things that this would do vs. the things that are bad. I hope that maybe the good things out weigh the bad. They do for me anyways. I do follow the rules and whatever the AMA Committee decides, I will follow then too. I would just like to try while there is time remaining.
One other thing. If we take the price cap idea and project it to even next year, that means that the majority of current planes then become obsolete. That certainly doesn't help Idon't think. Raising the weight limit does not obsolete our De Ja Vu's or any current design. It simply allows room for those that cannot make the weight and these folks are out there.
#198
NY
Scott, I appreciate that sentiment.
However, before you mentioned it I did not know about the higher weight limits elsewhere, so perhaps we can ask some Pattern organizations about the effects of the weight increase in other countries before we experiment with it here.
Seems to me if there is a metric available we should use it.
Maybe some of our UK and Oz posters could enlighten us a bit.
#199
My Feedback: (58)
Scott I am very big on outside the box thinking, my concern is solely based on past experience. As for the current gear being obsolete that can be addressed by a grandfather clause, but the cost cap will never gain traction.
Again, if raising the weight limit is considered you need to balance the equation and that would mean some other limit of equal value.
There are a lot of people reading this thread and I enjoy reading all the responses as you never know what a persons input can spawn in open conversation.
#200
My Feedback: (25)
ORIGINAL: MTK
I understand that it followed FAI, but why?
My point being, some people feel that the weight rule is antiquated and pointless because they have to spend a little extra time or money to conform to it. It is seen as an imposition and to continue to follow it promotes the herd mentality. I have made my stance on the weight rule known in the other thread, so I’m going to play devil’s advocate.
Since the reasoning for the genesis of the weight rule seems to be cloaked in ambiguity, and the best explanation that has been given is that it just was; why don’t we look at eliminating the size rule? After all, it’s been done that way for years. I’ve been looking for an excuse to sell my soul and every worldly possession to build a Dalton Extra 300 MEL with a DA200 anyway, so if I could fly it more by flying it legally in a pattern contest; that would be sweet.
Why is the weight rule less important than the size rule?
Scott, I would like some more information in your post 193. I would like to know which countries (specifically in Europe and Asia) have passed such rules. If possible, I would like to see a report from the aerobatic SIGs of each country that details:
1. When they raised their weight limit.
2. Why they raised their weight limit.
3. What ramifications they have seen, if any, from raising the weight limit.
4. Some sort of gauge of how much it has helped their sport; locally and nationally. I would envision this as being a graph showing the number of participants from events (excluding DNFs), and contrasting that with the numbers post-increase. I think a trend of several years prior to the weight increase’s introduction would show a good trend.
The purpose of this is to see if it actually helps gain an appreciable amount of participation from people in lower classes, or if it’s just water cooler banter amongst the peanut gallery and those who either don’t go to contests, or fly two rounds and leave.
My personal history will tell my feelings quite well. I’ve never had a ton of money to spend on the hobby, and I didn’t receive really any help from my parents when I was living at home. There is no way in the world that I could dole out the money that most ARFs command these days, not to mention not really being able to afford a kit recently. I can’t/couldn’t afford to build an airplane to conform to increasingly strict rules that require a different airplane, truthfully. That being said, I did have a rather large benefactor that helped me get into the hobby; Joey Hayes. We worked out a deal for his Partner that allowed me to start flying pattern. I flew that airplane from my first contest in Sportsman all the way through to my first several Masters contests several years later. This included two Nats participations. I honestly would probably still be flying it if I hadn’t lost it due to a battery issue (owner/operator induced).
The resale value of anything is drastically less, from what I’ve seen and experience, than what one pays for something. You can lose quite a bit of money selling an airplane to try and fund a newer one, and further be in the hole if you are upgrading. I could not do that. I can, however, be smart and put in the legwork ahead of time and have an airplane and equipment that will work for what I need it to and last me. Complaining about having to buy different batteries because they didn’t work for you because they were too heavy is a bit like complaining that you bought a Telemaster and are mad because you expected to be able to fly pattern with it.
For those that want to interject something about my whining about sponsorship dollars/support, save it. Not interested in that discussion and I promise you I have more facts to argue my case than anyone could possibly have conjectures.
In any case, if someone can answer the question of why the two-meter rule was made; a tangible, real reason why (akin to Keith’s explanation, which made me chuckle), and if the information that I requested regarding other country’s experiences with weight increase can be answered, maybe I will be able to see that I was wrong all along and that increasing the weight will contribute to the continued health of pattern. Honestly, I would not be opposed to checking those sources myself, and I would be happy to compile a report for presentation.
Until then, I will still see it as the same small group of folks that claim to not have a problem making weight, but are simply concerned modelers. I have my opinions, and many, more experienced modelers whom I truly respect and look up to, share these same opinions. I am more than happy to be proven wrong.
