(mini) servo gear grease
Old 02-20-2012 | 06:05 AM
Jetdesign's Avatar
My Feedback: (8)
Default (mini) servo gear grease
I was replacing the housings on my Airtronics mini servos and found I had to disassemble the gears and transfer to the new housing. Should I re-grease them, and if so, what's a good grease to use? I have white lithium grease spray, and the Neu motor grease laying around.
By the way, I will think twice before complaining about the cost of these little buggers - lots of precision little gears, precision housings to press-fit hold the pins, an AMD chip for control...
Thanks.
Old 02-20-2012 | 08:50 AM
My Feedback: (85)
Default RE: (mini) servo gear grease
I used some white grease i got in a small tube. can't remember the brand name right now. Tower Hobbies also sells Hitec grease.
Hitec part#58450
Tower part#LXN741
kind of pricey though
Old 02-20-2012 | 08:55 AM
My Feedback: (85)
Dug through the stash.
Woodland Scenics White Grease with Teflon
Part#HL657
Tower#LXKR90
Usually find it by the trains in a hobby shop if any are left.
Other then that a white lithium grease would work fine
Old 02-20-2012 | 08:58 AM
My Feedback: (10)
ORIGINAL: d_bodary
Hitec part#58450
Tower part#LXN741
i have always used white lithium grease. can be purchased at any auto or harware stores...
Larry Diamond
