Go Back  RCU Forums > RC Airplanes > Pattern Universe - RC Pattern Flying > RC Pattern Flying
Reload this Page >
ARIXTRA Build Thread by ISAAC NAJARY
Old 03-23-2013, 08:34 AM
  #276
najary
najary's Avatar
Default RE: ARIXTRA Build Thread by ISAAC NAJARY
To determinate exactly the battery tray location I assembled all the parts weighted the model and find the moment from the recommended C.G. (the weight is not include the motor battery, the battery tray and some other little parts of about 10 gram)
ID:	1865531   Click image for larger version
ID:	1865532   Click image for larger version
ID:	1865533   Click image for larger version
ID:	1865534   Click image for larger version
ID:	1865535   Click image for larger version
ID:	1865536   Click image for larger version
ID:	1865537   Click image for larger version
ID:	1865539   Click image for larger version
Old 03-23-2013, 09:49 AM
  #277
Malcolm H
Malcolm H's Avatar
Hi Isaac,
What I was suggesting was using S bus servos then there is no need for a decoder. Just one three core cable from the S bus socket on the Rx down to the back of the plane and if you want to a couple of sockets for the servo plugs with all three connections commoned. Alternatively solder the servo leads to the extension.
However I understand your desire to stick with what you know. I have a feeling that bus systems will become the norm in the same way that electric power did!
Malcolm
Old 03-24-2013, 01:51 AM
  #278
amram
amram's Avatar
מדהי×!!!!!!!!
Old 03-24-2013, 01:57 AM
  #279
Rune
מדהי×!!!!!!!!
didnt understand what you write , but I think it must be like nice or fantastic!
Wery nice work again Najary , hope you enjoy your new bird.
Old 03-24-2013, 05:08 AM
  #280
Jetstream
Absolutely beautiful!! Thanks for taking the time and effort to do the thread.
Old 03-24-2013, 07:26 AM
  #281
Malcolm H
Malcolm H's Avatar
ת×מי×*ו לי שזה עתיד!
Malcolm
Old 03-25-2013, 03:11 AM
  #282
najary
najary's Avatar
More
ID:	1866323   Click image for larger version
ID:	1866324   Click image for larger version
ID:	1866325   Click image for larger version
ID:	1866326   Click image for larger version
ID:	1866327   Click image for larger version
ID:	1866328   Click image for larger version
ID:	1866329   Click image for larger version
Old 03-25-2013, 03:44 AM
  #283
HARRIS-G
As always... another fantastic job with maximum weight reduction on the model.
Well done Isaak!!!
(I hope we meet again in another contest)
Harris
Old 03-25-2013, 05:48 AM
  #284
highfly3D
Superb... looks awesome.. nice build.
Old 03-26-2013, 06:57 AM
  #285
najary
najary's Avatar
Final assembling
ID:	1866761   Click image for larger version
ID:	1866762   Click image for larger version
ID:	1866763   Click image for larger version
ID:	1866764   Click image for larger version
ID:	1866765   Click image for larger version
ID:	1866766   Click image for larger version
Old 03-26-2013, 07:04 AM
  #286
najary
najary's Avatar
Final weight = 4,796 gram.
With Rhino Battery 1,203 gram and 21 X 13 APC prop.
ID:	1866769   Click image for larger version
File Type: pdf
Old 03-26-2013, 07:32 AM
  #287
Jetdesign
My Feedback: (8)
Jetdesign's Avatar
Fantastic! The plane looks great and your documentary is superb.
Isaac I have one question for you - with all the effort and equipment that goes into making a plane like this, why do you prefer not to use carbon propellers and lighter batteries? It seems like a pretty quick way to save 80-100g.
Maybe it just makes sense to save where you can, but not spend hundreds of dollars for that extra 80g?
Old 03-26-2013, 04:13 PM
  #288
tuny
Congratulations! absolutely beautiful!!!
Old 03-26-2013, 04:41 PM
  #289
nonstoprc
My Feedback: (90)
nonstoprc's Avatar
Wow! at 10.5734 lb with the batteries.
Old 03-27-2013, 06:40 AM
  #290
Mvelez
Beautiful job and amazing scheme not only in design but in color selection.
I have the exact same question as Joe Marri. seems pretty easy to save some extra 100 g with a prop and a spinner.
see you in RSA!
Marcelo
Old 03-27-2013, 11:25 PM
  #291
najary
najary's Avatar
ORIGINAL: Mvelez
see you in RSA!
Marcelo
Hi Marcelo and Joe,
I know that I can make the plane lighter by using a 40 pram or less carbon prop or by using a lighter battery (the sinner is the lightest in the market – Marquet-Spinner), that is why I mentioned what prop and battery I use so it is possible to calculate what is the plane potential weight.
My method is to build the plane as light as possible so I will have much spare weight so I can use any prop or battery that I want.
I prefer to use APC props because they are relative silence to carbon props despite they are heavier.
Best regards,
Isaac Najary
Old 03-28-2013, 01:07 AM
  #292
Rune
http://www.ofremmi.info/F3A/Technic/..._propeller.htm
I see you use a 20x13 I know PT has made a new lightweight version but it not that much to save on APC vs carbon on that size.
I think the carbon is about 40 gr (light) and apc is 86 gr ...I have used a PT (normal) 20x13 power is good but only is it 12gr lighter than the Apc.
I think F3a Unlimited has listed som lightweight carbon.
So Najary I think you correct about 40 gr on a prop and maybe spinner but not more , diffrent story if you had a 21X14 APC
Old 03-28-2013, 04:08 AM
  #293
cmoulder
Mejzlik also has ultralite props now. Weight of the Mej 20.5x12WEL is 43.1g vs 146.2 for APC 21x12W.
The Mej blade is very wide, so I would imagine the standard bladed props would be sub-40g.
Old 03-30-2013, 05:38 AM
  #294
najary
najary's Avatar
Today it was the test flight, I flew 4 flights, it seems that the plane have very good flight qualities.
ID:	1868125   Click image for larger version
ID:	1868126   Click image for larger version
ID:	1868127   Click image for larger version
ID:	1868128   Click image for larger version
ID:	1868129   Click image for larger version
ID:	1868130   Click image for larger version
ID:	1868131   Click image for larger version
Old 03-30-2013, 07:33 AM
  #295
Jetdesign
My Feedback: (8)
Jetdesign's Avatar
Good to hear. It really looks awesome. Congrats, and nice work
Old 03-30-2013, 07:36 AM
  #296
kingconsulting
Congrats Isaac! Looks real good. I've been quietly watching you build this and learned a lot of tips as you went on. Thank you.
Robert
Old 03-31-2013, 11:00 PM
  #297
najary
najary's Avatar
This is the first model I ever had that there is no need for any knife edge mixing!!!!
I moved the C.G. to 185 mm from the trailing edge.
Best regards,
Isaac Najary
Old 03-31-2013, 11:20 PM
  #298
PeterP
Hi Isaac,
Congratulations on the build. The model looks magnificent. I like the tinted canopy as it gives the model a little more class. I assume that you molded the canopy as it does not appear to be an option. Could you please explain the process of making a canopy and what type of material was used.
 Regards,
Peter
Old 04-01-2013, 12:19 AM
  #299
najary
najary's Avatar
ORIGINAL: PeterP
Hi Isaac,
Regards,
Peter
Hi Peter,
The tinted canopy can be an option, Pascal Nowik have the mold for the clear canopy.
I think you can order it from him, just like I did.
http://www.aerocompet.fr/
Best regards,
Isaac Najary
Old 04-26-2013, 12:12 PM
  #300
villalbi2003
hi Isaac
what kind of clear coat do you use?
i use acrilic color for paint but i have some problem with clear coat,
normally the type used for cars are very heavy and diffucolt to apply.
thanks in aadvance for any tips about this question.
regards
Alberto
