ARIXTRA Build Thread by ISAAC NAJARY
#183
My Feedback: (8)
RE: ARIXTRA Build Thread by ISAAC NAJARY
Hi Isaac,
Would you mind commenting on how you find the center of the slots for the rudder cable? I see you lay out the cable geometry, which I assume is based on the size of the control horns and the distance between them; what determines the exit location?
#184
ORIGINAL: gaRCfield
Hi Isaac,
Hi Isaac,
You right, I lay out the cable geometry based on the size of the control horns and the distance between them and the fuselage sides.
Then I measure the distance between the rudder hinges and the meeting point of the cables and the fuselage sides, it is 12.5 cm, see post 180 second picture.
Then I lay out the locations of the cable on the fuselage, sides see post 180 third picture.
Then I lay out the cable exit locations 12.5 cm from the rudder hinges, see post 180 fourth picture.
Best regards,
Isaac Najary
#186
ORIGINAL: Jeff Worsham
Isaac,
What kind of switch harness are you using? I've not seen one of those before. Thank you-
Isaac,
This is a hybridization I made from these two:
http://www.powerbox-systems.com/e/po...itch/start.php
http://www3.towerhobbies.com/cgi-bin...&I=LXJUW6&P=SM
Best regards,
Isaac Najary
#193
My Feedback: (28)
Coming from the days when color schemes consisted of mainly straight lines (usually only a few small curves to deal with), I'm glad to see how these "new fangled swoopy" color schemes can be accomplished. Never thought of making a template for an entire flying surface. Thanks for showing your process Isaac!
#196
ORIGINAL: can773
Fabulous as usual Isaac! Could you show the weight before and after covering for the wings? I am curious to know the difference.
Hope to see this airplane in South Africa!?
See the weights before covering in post 187.
I will post the weights after covering when it will be finish.
I am not so sore about South Africa.
Best regards,
Isaac Najary
