HK control linkage
Old 01-14-2013 | 11:12 AM
Default HK control linkage
Hi there!
Have you used these ball bearing links and horns from Hobby-king??
http://www.hobbyking.com/hobbyking/s...mm_5sets_.html
http://www.hobbyking.com/hobbyking/s..._5_10pcs_.html
Do you know what type of pushrod they use?
I've been using Robart super horns and dubro ball links, but they develop some serious slop after 1 year of use...
Thanks for the info!
Saludos,
Jean Paul
Old 01-14-2013 | 11:51 AM
Default RE: HK control linkage
Hi Jean
I'm using this item
all around in my F3A plane (electric C-50 14XL Hacker) from september 2010 and they are VERY GOOD
After 578 flies they still be like new.
Old 01-14-2013 | 12:10 PM
The only complaints I have about their BB clevis is that they don't include the spacer that goes between the bearing face and the control horn. MK used to include a metal spacer then they went to a plastic one. My first order from HK had a plastic spacer but later orders had no spacer at all.
Old 01-14-2013 | 01:02 PM
Thanks!
What pushrod size do you use?? Metric? 4-40?
There's not a lot of info on the site about this links...
Saludos,
Jean Paul
Old 01-14-2013 | 02:13 PM
ORIGINAL: shannah
I also had a plastic spacers
Pozdro
Les
