Go Back  RCU Forums > RC Airplanes > Pattern Universe - RC Pattern Flying > RC Pattern Flying
 Extreme Flight Vanquish 2m Motor !!! >
Old 03-23-2013 | 08:17 PM
Edge 540's Avatar
Default Extreme Flight Vanquish 2m Motor !!!
Has anyone tried this motor, or have on in their Vanquish now ??? Im thinking about putting this one in my ship. Thoughts ????
Mars-BL5943-215KV
Item Mars-BL5943-215kv
Voltage 27-42V
Power(W) 1900W
Lipo 10S
Prop (inch) 21*12
Turns 22T
shaft Diameter D2(mm) 8.0
shaftlenght L2(mm) 26.5
Diameter D1(mm) 59
Lengh L1(mm) 43
mounting scr.dia 4*M4,32mm
recomm.Timming High or Auto matic
Weight? 335g
Speed control Mars-BL90A
model weight 17kg
Old 03-23-2013 | 11:59 PM
Default RE: Extreme Flight Vanquish 2m Motor !!!
Gens Ace motors are made in the Sunray Technology factory -the same factory that makes:Hacker, Torque, Z-Hyperion motors;and LiPolice,Apache Turnigy SK3, OK Hobby Infinite, Shulman Aviation FURY, motors etc etc,
For this Gens ACE Mars-BL5943-215KV,see: http://www.rcuniverse.com/forum/fb.asp?m=11433501
-It has a weight of 438g, and has a 5020 stator - http://www.gensace.com/Gens-ace-Mars...V-Mars-BL90A-1
Most F3A motors have weight 550g to >600g,and most have a ~5030 stator (some have 5330 stator-e.g. Himax, Dualsky, if I remember)
I do not think this particular Gens Ace 5943 motor will have the required power for an F3A 2m plane.
The Gens ACE -Mars 5953-225KV -is 590g,has a 5030 stator;will have a better power level. It is similar to the HackerA60-S type motors (except the Gens Ace is a 14 pole motor, whereas the Hacker is 28 pole).
Other F3A motors made by the Sunray Tech factory -in addition to e.g. Hacker Q60-7M F3A, are:
Torque F3A "Silver Bullet", 580g, Kv 220, 7T, 28 pole
Shulman Aviation FURY 60/67-230 "F3A", 590g, Kv 230, 28 pole
(these 2 motors have identical appearance -just slightly different Kv's)
and also:
LiPolice LPA-F3A-5030-210KV, 580g, Kv 210, 7T, 28 pole
OK Hobby Infinite A5030-210 (For F3A), 580g, Kv 210, 7T, 28 pole,
Mega Power TAURUS MPA5030-210KV (F3A), 580g, Kv 210, 7T, 28 pole
(these 3 motors are completely identical -just different external colours-will be the same internally as Torque and Shulman)
and also:
Turnigy F3A SK3 Competition Series 28 Pole Outrunner, Kv 240(will also be similar internally to the others ...)
All these motors are made together, in the Sunray Tech factory -they just have different cosmetic external appearance...
They also make the Apache X60 Acro-Competition motors, which look identical to Torque and Shulman, but are 20 pole motors.
Hope this helps.</p>
Old 03-24-2013 | 10:04 AM
Agree it looks a little light for a 2-M aircraft. Only handles 1900 watts. I think my AXI FAI is more like a 3000 watt motor.
Old 03-25-2013 | 02:33 PM
So has anyone done a prop testing? Like the <span style="color: rgb(0, 0, 0); font-family: arial, sans-serif; font-size: 13px; font-style: normal; font-variant: normal; font-weight: normal; letter-spacing: normal; line-height: 18px; orphans: auto; text-align: start; text-indent: 0px; text-transform: none; white-space: normal; widows: auto; word-spacing: 0px; -webkit-text-size-adjust: auto; -webkit-text-stroke-width: 0px; background-color: rgb(255, 255, 255); display: inline !important; float: none;">APC 20.5 X 14?</span>
Old 03-25-2013 | 11:06 PM
marbar's Avatar
Hello!
Here is static test of GensAce motor on slovenian lengague: http://www.e-modelar.net/clanki-97.html
This motor is NOT capable to power your 2x2m pattern model. Windings are strong, but magnet system is not strong enough- los sincronity over 62A. Timing must be 20 deg.
Best regards!
Marko
